| | USB Storage drive registers but not accible? When I pop a USB storag drive (250mb) into any USB slot (either an original one on the PC or off a hub) it pops up on my computer as Removable Drive (J), but when I click on Drive J I get ' Please insert a disk into Removable Disk (J) - it won't allow me to format it wither. Anything I can do to get it going or is it a gonner? |
| | Re: USB Storage drive registers but not accible? Eurofeeds wrote: Quote: > When I pop a USB storag drive (250mb) into any USB slot (either an > original one on the PC or off a hub) it pops up on my computer as > Removable Drive (J), but when I click on Drive J I get ' Please insert a > disk into Removable Disk (J) - it won't allow me to format it wither. > Anything I can do to get it going or is it a gonner? had a failure. -- Best Regards, Keith http://home.comcast.net/~kilowattradio/ |
| | Re: USB Storage drive registers but not accible? "Keith" <kilowattradio@xxxxxx-reply-to.invalid> wrote in message news:h7anfu$2eg$1@xxxxxx-september.org... Quote: > Eurofeeds wrote: Quote: >> When I pop a USB storag drive (250mb) into any USB slot (either an >> original one on the PC or off a hub) it pops up on my computer as >> Removable Drive (J), but when I click on Drive J I get ' Please insert a >> disk into Removable Disk (J) - it won't allow me to format it wither. >> Anything I can do to get it going or is it a gonner? > Try it on a different computer, but most likely it has been worn out or > had a failure. > > > -- > Best Regards, Keith > http://home.comcast.net/~kilowattradio/ magazine. |
| vista home premium 32 bit | Re: USB Storage drive registers but not accible? have 500gig new drive sys info shows there ,but not in my computor possible not formatted or yours may be formatted apple? |
| | Re: USB Storage drive registers but not accible? On 8/28/09, the entity Eurofeeds wrote this: Quote: > When I pop a USB storag drive (250mb) into any USB slot (either an original > one on the PC or off a hub) it pops up on my computer as Removable Drive (J), > but when I click on Drive J I get ' Please insert a disk into Removable Disk > (J) - it won't allow me to format it wither. Anything I can do to get it > going or is it a gonner? That will tell you the status of the drive and, if needed, allow you to format it. -- Gene Bloch 650.366.4267 lettersatblochg.com |
| C:\ drive storage issue | Vista file management | |||
| Need help with an external storage drive with Vista OS | Vista hardware & devices | |||
| Unknown storage on c: drive | Vista General | |||
| Back up a storage drive in Vista? | Vista performance & maintenance | |||
| Vista DHCP Registers Prior IP Addresses in DNS?!?!?! | Vista networking & sharing | |||
