Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Programs Will Not Start
Update your Vista Drivers
Thread Tools Display Modes
Old 06-04-2006   #1 (permalink)
CEJ
Guest
Hi, I have Windows Vista Beta 2 build 5384.
When I try to open some programs like controll panel and windows photo
gallery nothing happens, it just soesnt load. Also When I try to open
Controll Panel only the edge of the program appears nothing in the midlle.
Any help would be apreciated, Cej
P.S I dony have aero, How do I get it
Old 06-04-2006   #2 (permalink)
Andre Da Costa [Extended64]
Guest
Re: Programs Will Not Start
Its possible that this is bad install, Control Panel items loads just fine
here, so does Photo Gallery. Was this is a clean install or upgrade from a
prior version of Windows? Are there any error messages, are the Control
Panel and Photo Gallery issues the only ones you are experiencing?
As for Glass, that depends on if your video card is supported. Could you
tell us the model and brand you are using and vRAM its using? Vista requires
a minimum 64-MBs of vRAM work, 128 MB recommended.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"CEJ" <CEJ@discussions.microsoft.com> wrote in message
news:FCAF5C22-F849-403F-B667-28D4CE870D2F@microsoft.com...
Old 06-04-2006   #3 (permalink)
CEJ
Guest
HI, I have A dell XPs M140 with Intel Media Accelerator, [I found out it is
not sufficient for Aero] 2.00 ghz processor. When I say I see just the edges
for Controll Panel I mean the window opens and you can see the border around
it with the minimize exit and enlarge buttons but hte "interior" is just a
mirror image of what is behind it. After that it just closes, There are no
error messges. On Windows photo Gallery when you click it nothing at all
happens, nothing whatsoever. This was not a clean install. I wonder if it is
possible to format the hardrive and then reinstall [worst case scenario] the
os. Thanks for the help on aero but if What I have heard is correct its not
worth the hassle.
Thanks, Ps is there a way to run diagnostics on the operating system to see
what the prblem is.
> Andre
Old 06-12-2006   #4 (permalink)
samload xps m140
Guest
RE: Programs Will Not Start
I have a similar problem
I have a Dell XPS m140
when I run my pictures , photo gallery I get a bluescreen and it restarts,
real bad
It might be the driver for the video.
any fixes for this?
Old 06-12-2006   #5 (permalink)
samload xps m140
Guest
I have a similar problem. I own a Dell XPS m140
I installed Vista Beta 2
But when i go to photo gallery or my pictures , or change the picture from
my profile i get a bluescreen...
what can i do?
Display Modes
Start/All Programs a4hkb Vista General 1 07-31-2008 07:28 AM
Start up Programs brat1969 Vista General 0 07-28-2008 01:19 PM
Cannot start programs from the start menu Ana Vista General 1 12-10-2007 04:26 PM
Can't start certain programs from Start Menu Programatix Vista General 8 05-26-2007 04:12 AM
Weirdest problems.Can't start programs from start menu and use Cop Mihai Vista General 1 05-12-2007 02:28 AM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
