| | 4GB of physical memory shows as less than 3 in system properties I just upgraded my physical memory to 4GB but under system properties, it only shows as 2.7 or so. 32 Bit Windows 7. Why? ~alan |
| | Re: 4GB of physical memory shows as less than 3 in system properties 32 bit versions of Windows can only address about 3.2 GB. -- Windows 7 RC http://get.live.com/wlmail/overview http://download.live.com/wlmail "Alan Shepro" <a.shepro@xxxxxx> wrote in message news:C6CB2F0D.492%a.shepro@xxxxxx Quote: > I just upgraded my physical memory to 4GB but under system properties, it > only shows as 2.7 or so. 32 Bit Windows 7. Why? > > ~alan > |
| | Re: 4GB of physical memory shows as less than 3 in systemproperties On Mon, 07 Sep 2009 22:41:59 -0400, Dave wrote: Quote: > 32 bit versions of Windows can only address about 3.2 GB. |
| Vista Home Premium x64 | Re: 4GB of physical memory shows as less than 3 in system properties I've had a 32bit windows showing 4GB of memory Try putting only 1 stick in then starting then shutdown and put in another until all are in also hit ctrl alt delete under the performance tab you will see a section called Physical Memory (MB) that should tell you exactly how much memory windows is using one last thing these forums are for 64-bit versions of windows so don't post 32 bit problems in here |
| | RE: 4GB of physical memory shows as less than 3 in system properties http://members.cox.net/slatteryt/RAM.html "Alan Shepro" wrote: Quote: > I just upgraded my physical memory to 4GB but under system properties, it > only shows as 2.7 or so. 32 Bit Windows 7. Why? > > ~alan > > |
| | #6 (permalink) |
| | Re: 4GB of physical memory shows as less than 3 in system properties > these forums are for 64-bit versions of windows Quote: > so don't post 32 bit problems in here and for 64 bit As for the first part of your post. That is a bunch of croq and sure sounds like you have no idea what you are saying -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "Steve0" <guest@xxxxxx-email.com> wrote in message news:bde98b9d2e3235ede5038d51473464e4@xxxxxx-gateway.com... Quote: > > I've had a 32bit windows showing 4GB of memory > > Try putting only 1 stick in then starting > then shutdown and put in another > > until all are in > > also hit ctrl alt delete > under the performance tab you will see a section called > Physical Memory (MB) > > that should tell you exactly how much memory windows is using > > one last thing > > these forums are for 64-bit versions of windows > so don't post 32 bit problems in here > > > -- > Steve0 |
| | #7 (permalink) |
| | Re: 4GB of physical memory shows as less than 3 in system properties ray wrote: Quote: > On Mon, 07 Sep 2009 22:41:59 -0400, Dave wrote: > Quote: >> 32 bit versions of Windows can only address about 3.2 GB. > So, where is the other .5gb? for the 512 meg. |
| | #8 (permalink) |
| | Re: 4GB of physical memory shows as less than 3 in system properti > Quote: > these forums are for 64-bit versions of windows > so don't post 32 bit problems in here > "Steve0" wrote: Quote: > > I've had a 32bit windows showing 4GB of memory > > Try putting only 1 stick in then starting > then shutdown and put in another > > until all are in > > also hit ctrl alt delete > under the performance tab you will see a section called > Physical Memory (MB) > > that should tell you exactly how much memory windows is using > > one last thing > > these forums are for 64-bit versions of windows > so don't post 32 bit problems in here > > > -- > Steve0 > |
| | #9 (permalink) |
| Vista Home Premium x64 | Re: 4GB of physical memory shows as less than 3 in system properties Since when? The website is vistaX64 This website was made for windows 64 bit problems. so if you are going to post something about a 32bit system then you should make it very clear that you are posting a 32bit problem to Peter I was telling him to put one stick in at a time and run the computer and every time he restarts add another stick and as for the task manager well I know I'm 100% right on that one. |
| | #10 (permalink) |
| | Re: 4GB of physical memory shows as less than 3 in system properties Steve0 <guest@xxxxxx-email.com> wrote: Quote: > >Since when? >The website is vistaX64 >This website was made for windows 64 bit problems. You're a complete moron and are clueless as well. That "website" is a gateway to the MS Usenet newsgroups. It leeches the vast majority of its posts from MS servers - all those from users whose number of posts are "n/a" are the leeched posts, i.e., they come from OUTSIDE that site. |
| Vista 64 Installed Physical Memory vs Total Physical Memory | Vista General | |||
| Re: Total Physical Memory on Task Manager shows wrong value? | Vista General | |||
| Difference between Physical Memory and the Vista System Memory (Ra | Vista hardware & devices | |||
| Memory - System shows less than actually installed | Vista General | |||
