Vista - Registry problem when running program
Old 09-10-2009   #1 (permalink)
zeem
http://img406.imageshack.us/img406/2784/40547580.jpg
"Access to registry key 'HKEY_CLASSES_ROOT\.pgk' is denied"
Th program runs well on 32 bit vista and XP but I have 64bit and it
doesn't work.
Is there a solution?
zeem
zeem's Profile: http://forums.techarena.in/members/134024.htm
View this thread: http://forums.techarena.in/vista-help/1244646.htm
Old 09-10-2009   #2 (permalink)
LVTravel
Re: Registry problem when running program
"zeem" <zeem.3yaznb@xxxxxx> wrote in message
news:zeem.3yaznb@xxxxxx
> doesn't work.
> zeem
What program?
Old 09-10-2009   #3 (permalink)
zeem
I doubt you are familiar with the program. It is used to edit games on
pc. Does it matter to know? and is there way to fix this?
zeem
Old 09-10-2009   #4 (permalink)
Gordon's Psychiatrist
Did you check with the manufacturer of the software to see if it works with 64 bit? How about
forums? Do they have forums? Did you google the product to see if anyone had any issues with
it on 64 bit?
Old 09-10-2009   #5 (permalink)
Richard G. Harper
You'd need to contact whoever wrote and/or distributed this program for an
answer to that.
> doesn't work.
> zeem
Old 09-10-2009   #6 (permalink)
Peter Foldes
Contact the manufacturer of the unknown program
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
> doesn't work.
> zeem
Old 09-10-2009   #7 (permalink)
LVTravel
"zeem" <zeem.3ybdjb@xxxxxx> wrote in message
news:zeem.3ybdjb@xxxxxx
> zeem
As you can see from the most other posts, without knowing the name of the
program in question you need to go back to the creator of the program to
answer the question if it is compatible with a 64 bit operating system. Had
you identified this unknown program someone may have been able to answer
your question without contacting the writer of the program. Now since you
don't give a name we can only think that this is a crack program for your
"games."
Old 09-11-2009   #8 (permalink)
zeem
It is not a crack. It is just an editor to add edits to your game to
improve it. here is the link. It is called player GDB manager.
http://rs210.rapidshare.com/files/47369391/PGM_1.7.rar
zeem
Old 09-11-2009   #9 (permalink)
Dave-UK
"zeem" <zeem.3yc2jb@xxxxxx> wrote in message news:zeem.3yc2jb@xxxxxx
> zeem
You might get more help from the forums mentioned in the readme file.
Quote:
HOPE everything goes well, post any bugs found at www.soccergaming.tv or
http://www.wevolution.org/forum/show...5117&#pid65117
Old 09-11-2009   #10 (permalink)
zeem
So I have 64-bit. I download the 64-bit virtual file, install it and
that it or do I have to install XP or 32 bit all over again?
zeem
Problem running old program on non-admin account Software
Solved Running program in startup as administrator without any problem Software
Registry Cleaner program slow Tutorials
Recommended Registry Cleaner Program? Software
Register a program in the Registry Vista General
