RB
Vista - I am having problems using the vista xps viewer
09-13-2009   #1
Greg
Hello,
I am having problems using the vista xps viewer.
I have dot net 3. and viewer turned on. just like this:
To find out if you have .NET Framework 3.0
1. Click the Start button , click Control Panel, and then click
Programs.
2. Under Programs and Features, click Turn Windows features on or
off. If you are prompted for an administrator password or confirmation,
type the password or provide confirmation.
3. Look for .NET Framework 3.0 in the list of features. If it's
listed, double-click the folder to view its contents.
4. In the .NET Framework 3.0 folder, make sure that the XPS Viewer
check box is selected, and then click OK.
I have also tried to create a shortcut like this
C:\Windows\System32\XPSViewer\XPSViewer.exe %1
and drag the xps file on it. But nothing happens.
I do not even see the process starting in the task manager
also I do see the XPSViewer.exe file in that directory.
any ideas?
thanks
09-13-2009   #2
Bob
Re: I am having problems using the vista xps viewer
FIX: You cannot open an XPS document by using the Microsoft XPS Viewer on a
Windows Vista x64 edition-based computer that has .NET Framework 3.5 SP1
installed
http://support.microsoft.com/kb/967190
"Greg" <greg@newsgroup> wrote in message
news:OKWTsmLNKHA.5128@newsgroup
Quote:
> Hello,
> Programs.
> any ideas?
> thanks
09-13-2009   #3
Greg
thanks, but I am not running 64 bit vista.
I have windows vista home basic
"Bob" <bob@newsgroup> wrote in message
news:u5UCnsMNKHA.3992@newsgroup
> a Windows Vista x64 edition-based computer that has .NET Framework 3.5 SP1
> installed
Quote:
>> Hello,
>> Programs.
>> any ideas?
>> thanks
09-14-2009   #4
Gene E. Bloch
On 9/13/09, the entity Greg wrote this:
But Windows Vista Home Basic can exist in a 64-bit version, according
to Microsoft...
>> installed
Quote:
>>> Hello,
>>> Programs.
>>> any ideas?
>>> thanks
Gene Bloch 650.366.4267 lettersatblochg.com
RB
Similar Threads for: I am having problems using the vista xps viewer
XPS Viewer EP - How to Maximize the Viewer on Open Vista General
Nero problems in Event Viewer Software
Windows Photo Viewer zoom vs. Picture/Fax Viewer Vista music pictures video
Replace Picture & Fax Viewer with a new, lightweight image viewer Vista print fax & scan
