| 09-27-2009 | #1 (permalink) |
| | USB Flash Drive Installation Kits I have enjoyed being able to install Vista and Windows 7 from a bootable USB Flash Drive. I have acquired couple of 8 and 16GB USB Flash drives and was wondering if it is possible to keep multiple installations on a single flash drive, for example, Windows 7 32 bit, Windows 7 64 bit, etc. To create a bootable USB Flash drive, from Vista or Windows 7, I use these commands: 1. DiskPart 2. List Disk 3. Select Disk # 4. Clean 5. Create Partition Primary 6. Active 7. Format fs=FAT32 quick 8. Assign 9. Exit Diskpart then Copy Installation from DVD to USB drive Thanks, ~alan |
| My System Specs |
| 09-27-2009 | #2 (permalink) |
| | Re: USB Flash Drive Installation Kits LOL. -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "~~Alan~~" <a.shepro@newsgroup> wrote in message news:enSN8x2PKHA.508@newsgroup Quote: >I have enjoyed being able to install Vista and Windows 7 from a bootable USB Flash >Drive. > > I have acquired couple of 8 and 16GB USB Flash drives and was wondering if it is > possible to keep multiple installations on a single flash drive, for example, > Windows 7 32 bit, Windows 7 64 bit, etc. > > To create a bootable USB Flash drive, from Vista or Windows 7, I use these > commands: > 1. DiskPart > 2. List Disk > 3. Select Disk # > 4. Clean > 5. Create Partition Primary > 6. Active > 7. Format fs=FAT32 quick > 8. Assign > 9. Exit Diskpart then Copy Installation from DVD to USB drive > > Thanks, > ~alan > > |
| My System Specs |
| 09-27-2009 | #3 (permalink) |
| | Re: USB Flash Drive Installation Kits It's pretty straightforward - Ramesh has an easy tut here : http://www.windowsvalley.com/blog/cr...in-single-dvd/ You should be able to get both bit versions of Vista and 7 into a single massive install.wim - if it takes your fancy. Hope it helps SIW2 I have enjoyed being able to install Vista and Windows 7 from a bootable USB Flash Drive. I have acquired couple of 8 and 16GB USB Flash drives and was wondering if it is possible to keep multiple installations on a single flash drive, for example, Windows 7 32 bit, Windows 7 64 bit, etc. To create a bootable USB Flash drive, from Vista or Windows 7, I use these commands: 1. DiskPart 2. List Disk 3. Select Disk # 4. Clean 5. Create Partition Primary 6. Active 7. Format fs=FAT32 quick 8. Assign 9. Exit Diskpart then Copy Installation from DVD to USB drive Thanks, ~alan |
| My System Specs |
| Similar topics to: USB Flash Drive Installation Kits | ||||
| USB Bootable Vista Installation Flash Thumb Drive | Tutorials | |||
| USB flash drive installation | Vista installation & setup | |||
| Flash Drive has no drive letter... Not in Disk Management | Vista hardware & devices | |||
| Pen drive/USB flash drive showing as floppy disk | Vista General | |||
| LastWriteTime and Locating the drive letter of a flash drive. | PowerShell | |||
