Vista - Boot Problem
Old 09-30-2009   #1 (permalink)
Michael
Boot Problem
Hi. I just finished a fresh install of Vista 64bit. Install went smoothly,
but the system won't boot unless I disconnect a second 1.5TB which I
partitioned 100GB for Windows 7. I unplug the drive and Vista boots fine,
then if I plug the second drive in, Vista freezes. I noticed in the repair
window Windows 7 didn't show up so I booted to the 7 disk and repaired the
partition with Windows 7. Now when I use the Vista disk to boot to repair,
both OS's show up with 7 showing as (recovered), but Vista still won't boot
unless I disconnect the 7 drive. Please help. All my backups are on the
main partition of the second drive.
Thanks,
Mike
Old 09-30-2009   #2 (permalink)
Michael
Re: Boot Problem
"Michael" <majdnhgfiwo@newsgroup> wrote in message
news:OPvc7whQKHA.764@newsgroup
> smoothly, but the system won't boot unless I disconnect a second 1.5TB
> which I partitioned 100GB for Windows 7. I unplug the drive and Vista
> boots fine, then if I plug the second drive in, Vista freezes. I noticed
> in the repair window Windows 7 didn't show up so I booted to the 7 disk
> and repaired the partition with Windows 7. Now when I use the Vista disk
> to boot to repair, both OS's show up with 7 showing as (recovered), but
> Vista still won't boot unless I disconnect the 7 drive. Please help. All
> my backups are on the main partition of the second drive.
> Thanks,
> Mike
Got it fixed. Booted to Win 7 disk and deleted the partition.
"Don't pick a fight with an old man.
If he is too old to fight, he'll just kill you."
Boot problem Vista General
boot problem Vista installation & setup
Dual Boot Problem - Misplaced Boot Sector Vista General
Dual Boot Problem - Misplaced boot sector Vista General
