1.    10 Oct 2009 #1
    MXC Guest
    Please do not Power off or unplug your machine
    It is second time in this month.
    When I tried reload the windows, It would not start and only show:
    Installing Update 3 of 5
    (Or Installing 5 of 5)
    It will last forever,
    The only way is turn off and unplug the machine to let it start windows.
    I do not know if it is really update windows vista, CA antivirus or some
    other program.
    I do not know other person have some experience
    Thanks
  2.    10 Oct 2009 #2
    Gene E. Bloch Guest
    Re: Please do not Power off or unplug your machine
    > other program.
    > Thanks
    Everyone with Vista or XP has experienced this when they have updated. It
    can take a long time. You have to wait long enough. Turning it off manually
    may have caused damage.
    Gene E. Bloch letters0x40blochg0x2Ecom
  3.    10 Oct 2009 #3
    ray Guest
    >> Please do not Power off or unplug your machine Installing Update 3 of 5
    >> windows.
    >> some other program.
    >> Thanks
    > It can take a long time. You have to wait long enough. Turning it off
    > manually may have caused damage.
    How would you tell
  4.    10 Oct 2009 #4
    MXC Guest
    If waiting even one hour or a little more, OK
    But after several hours I thought it might in dead loop
    then I decided menually turned off windows and even I had to unplug the
    machine.
    After power on the window restarted and I did not find any other thing
    wrong.
    "Gene E. Bloch" <not-me@newsgroup> wrote in message
    news:r910itboi5i2.1l629nd0dron7.dlg@newsgroup
    >> other program.
    >> Thanks
    > manually
  5.    10 Oct 2009 #5
    University of Kentucky
    Windows Vista Enterprise x64 SP2
    Local Time: 10:59
    usa us kentucky
    You can learn more about updates here. And, as Gene said, we've all gone through this.
    http://www.microsoft.com/windows/dow...dowsvista.mspx
  6.    12 Oct 2009 #6
    Gene E. Bloch Guest
    OK, several hours is definitely bad, and I would've done the same as you
    did. There's really no other choice at that point. And I would have scanned
    for damage afterwards (chkdsk and fsk, for example).
    I'm glad it came out OK. Scary... (or should I say :scary:?)
    > machine.
    > wrong.
    >>> other program.
    >>> Thanks
    >> manually
  7.    18 Oct 2009 #7
    MXC Guest
    I experienced another two, Both keep me waiting about 10 hours.
    Then I checked windows update history and just told me it was update
    security update for VS and end up with "failed".
    Then I downloaded this upate and run it under winows, only took some
    minites and end up with success
    >> other program.
    >> Thanks
    > manually
Please do not power off of unplug machine
I am running Vista Ultimate 32bit, I started getting this message yesterday and it says " Installing update 1 of 4 " and I havn't seen anything...
General Discussion
Half Post only until unplug and replug!
My Intel P5 Vista 32 machine will not turn on and boot totally until I unplug it and plug it in again. The POST stops at the end of the the RAM check...
General Discussion
Should unplug my ethernet cable to format?
I was just told that if and when I reformat I need to unplug my ethernet cable. Correct or incorrect? Some help please?
General Discussion
Freeze on Unplug
When I unplug my AC Cord on my Notebook my system crashes. Locks up and the only option is to power down, and restart the computer. Does anyone...
Vista performance & maintenance
Unplug PC?
Sorry if this is the wrong group. Going away for 10 days. Using a Gateway Laptop with Vista. Should I unplug and let the battery do what ever for the...
Vista General
USB device unplug causes power loss
Hi I installed a Vista Business edition on my computer everytime i unplug my usb mouse, keyboard or any usb device from the usb jacks on my...
Vista hardware & devices
Unplug laptop and I get BSOD.
I have a Dell 6400/E1505 laptop with 1.86GHZ core duo processor and when I unplug the power cord it BSOD's and turns off. I can then turn it on on...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
