Is there a way to see how long a process has been running
  1. #1
    Phillip Pi Guest
    Hello.
    Is there a way to see how long a process has been running in a current
    Windows session? For an example, how long has calc.exe been running
    since it started? I also don't mean its CPU time either that I see in
    Task Manager. I just want to know how when it started.
    Thank you in advance.
    Phillip Pi
    Senior Software Quality Assurance Analyst
    Partner Engineering/Internet Service Provider/Symantec Online Services,
    Consumer Business Unit
    Symantec Corporation
    www.symantec.com
    Email: phillip_pi@newsgroupC (remove SYMC to reply by e-mail)
    Please do NOT e-mail me for technical support. DISCLAIMER: The views
    expressed in this posting are mine, and do not necessarily reflect the
    views of my employer. Thank you.
  2. #2
    JS Guest
    Re: Is there a way to see how long a process has been running
    "Phillip Pi" <phillip_pi@newsgroup> wrote in message
    news:umPpXM4SKHA.220@newsgroup
    > Hello.
    > Windows session? For an example, how long has calc.exe been running since
    > it started? I also don't mean its CPU time either that I see in Task
    > Phillip Pi
    > www.symantec.com
    To find and display a process and when it started try Process Explorer:
    http://technet.microsoft.com/en-us/s.../bb896653.aspx
    Once you have Process Explorer installed and running:
    In the taskbar menu select 'View' and check:
    'Show Process Tree' and the 'Show Lower Pane' options.
    Next right click on any column and 'select columns'
    Now click on the 'Process Performance' tab and
    check the 'Start Time' box.
    JS
    http://www.pagestart.com
  3. #3
    3c273 Guest
    Process Explorer from the MS web site. Double click the process you are
    interested in and the start time is on the first tab.
    Louis
    > Hello.
    > Phillip Pi
    > www.symantec.com
  4. #4
    Ant Guest
    On 10/12/2009 2:46 PM PT, JS typed:
    Perfect and thanks.
    "Even the sharpest ear cannot hear an ant singing." --Sudanese
    /\___/\
    / /\ /\ \ Phil/Ant @ http://antfarm.ma.cx (Personal Web Site)
    | |o o| | Ant's Quality Foraged Links (AQFL): http://aqfl.net
    \ _ / Nuke ANT from e-mail address: philpi@newsgroup
    ( ) or ANTant@newsgroup
    Phil. (aka Ant) is currently not listening to any songs on his home
    computer.
  5. #5
    Ant Guest
    Perfect and thanks.
    On 10/12/2009 3:58 PM PT, 3c273 typed:
    > Louis
    /\___/\
    computer.
  6. #6
    JS Guest
    "Ant" <ant@newsgroup> wrote in message
    news:e9J7PsATKHA.1792@newsgroup
    > Perfect and thanks.
    > /\___/\
    > computer.
    You're welcome.
    Process Explorer has a lot of features so experiment/explorer a little.
    JS
Is there a way to see how long a process has been running problems?
Vista takes long time to shut down hanging process hhh3h Vista General 10 16 Apr 2009
long time log in process qnguyen Vista General 1 11 Feb 2008
System restore process takes a long time veranyon Vista General 2 11 Feb 2008
Running disk defragmenter again still takes long Mickey Segal Vista performance & maintenance 4 09 Apr 2007
Long Indexing Process after each logon PUAV Vista file management 0 16 Jan 2007
