Vista - [Off Topic] LCD monitor (no signal)
Old 11-11-2006   #1 (permalink)
nicholas
I know this is nothing to do with windows vista but I do not know where I
could post this question.
The problem is I have now moved over to a 20" Asus PW201 LCD monitor which
is connected to a Vida 7900 GTO graphics card (I used to have a 20 CRT
monitor). The problem is when I hibernate and switch the monitor off and I
go to restart the computer (switching the monitor on first) the monitor says
that there is no signal?
Any help or information would be gratefully appreciated
If someone knows a better place to post this sort of question it would be
good to know as well.
Many thanks
NIK
Old 11-11-2006   #2 (permalink)
Dennis Pack
Re: [Off Topic] LCD monitor (no signal)
Nicholas:
Verify that S3 is enabled in the bios and that video resume from S3
is enabled.
"nicholas" <niknik1971NOSPAM@btinternet.com> wrote in message
news:48C3D816-DBB3-46C1-A54D-06A38CD3092A@microsoft.com...
> says that there is no signal?
> Many thanks
> NIK
Old 11-11-2006   #3 (permalink)
Rick Rogers
Have you checked with Asus for an updated monitor.inf (driver) file to use?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
> Many thanks
> NIK
Old 11-11-2006   #4 (permalink)
nicholas
Dennis thanks for your reply.
I have done some tests and it seems that if I hibernate and leave the
monitor switched on I have no problems when the computer switches back on?
next time I reboot I shall check that setting in the BIOS.
NIK
"Dennis Pack" <dennispack at hotmail dot com> wrote in message
news:2CF636F4-CAE6-4932-819E-0C1DA34AB7E7@microsoft.com...
> Nicholas:
> is enabled.
>> which is connected to a Vida 7900 GTO graphics card (I used to have a 20
>> CRT monitor). The problem is when I hibernate and switch the monitor off
>> and I go to restart the computer (switching the monitor on first) the
>> monitor says that there is no signal?
>> Many thanks
>> NIK
Old 11-11-2006   #5 (permalink)
nicholas
Thanks for the reply Rick.
I went to the Asus website and unfortunately there are no downloads for
that.
I had a look on the supplied CD and there are no monitor.inf files there
either?
NIK
"Rick Rogers" <rick@mvps.org> wrote in message
news:%23SVAVscBHHA.144@TK2MSFTNGP02.phx.gbl...
> Hi,
> use?
> Best of Luck,
>> Many thanks
>> NIK
Old 11-11-2006   #6 (permalink)
chinga69
how are you connecting to the monitor
dvi or ?
it might be defaulting to a connection your not using
i had similar problem with a benq 20 in widescreen
chinga69
cheers chinga69
chinga69's Profile: http://www.64bit-world.com/forums/member.php?u=324
View this thread: http://www.64bit-world.com/forums/sh...ad.php?t=55672
Old 11-11-2006   #7 (permalink)
nicholas
Thanks for the reply chinga69
I am connecting my monitor by a DVI-D cable.
NIK
P.S I have connected it to the default monitor port (twin DVI ports in the
graphics card)
NIK
"chinga69" <chinga69.2h4o50@no-mx.forums.yourdomain.com.au> wrote in message
news:chinga69.2h4o50@no-mx.forums.yourdomain.com.au...
> dvi or ?
> chinga69
> cheers chinga69
Old 11-11-2006   #8 (permalink)
chinga69
yes but is it the default on the monitor
when it wakes up switch the monitor through all conections
you should have a button to select the different connections and see
if your screen comes back
chinga69
cheers chinga69
Old 11-12-2006   #9 (permalink)
Stuart
I have an NVidia 7300GS on an Asus P5WD2 Premium running vista RC2 and I
have the same problem. If I reboot with the LCD off then the system loses
the second display on the DVI connection, its a bugger to get it redetected.
I have simply had to ensure that I only turn it off manually, and make
absolutely sure that the LCD is on when the machine is resterted.
The same thing used to happen on XPMCE2005
If you find out any information I'd be grateful if you could post it here as
its a real PITA!
Cheers
news:3BF27D23-8B9A-4923-AFBD-F9BF3D959762@microsoft.com...
> that.
> either?
> NIK
>> Hi,
>> use?
>> Best of Luck,
>>> be good to know as well.
>>> Many thanks
>>> NIK
Solved need help, no signal to monitor at startup General Discussion
monitor no signal Vista installation & setup
Monitor Loses signal on boot up Vista hardware & devices
Monitor Show 'No Signal' when i reboot or turn on pc Vista hardware & devices
[Off Topic] LCD monitor (no signal) Vista hardware & devices
