Vista - Start menu links issue.
Old 10-23-2009   #1 (permalink)
beyond_illusions
Hello.
I have a bizzare problem here.
Today I installed Corel X creative suite.
After the installation, when browsing the start menu/programs/corel x I
noticed that the Corel Draw application has no icon and cant be
launched. I right clicked it and chose the option "Open With", I ticked
"Always use this program to open this file" option ON and then chose
"Corel Draw" as the application.
What that did was link ALL of my *.LNK files to Corel Draw.
Now Every single link I have in my Start Menu executes Corel Draw
instead of the program it was originaly ment to launch. Every icon in
the start menu is now the Corel Draw filetype icon.
After right-click / properties, every single link in start menu still
has its target program in the dialog box, as it should have. But somehow
the system ignores the program link and opens the "link" as a file
instead following the link's link.
I hope you get what I mean.
Soo.... what can I do to fix this?
Thanks!
beyond_illusions
beyond_illusions's Profile: http://forums.techarena.in/members/147936.htm
View this thread: http://forums.techarena.in/vista-help/1262417.htm
Old 10-23-2009   #2 (permalink)
Re: Start menu links issue.
Hello Beyond Illusions,
You can download and merge the "lnk" .reg file in the tutorial below to restore the default lnk (shortcut) associations. It should restore this for you.
Default File Type Associations - Restore
Quote  Quote: Originally Posted by beyond_illusions View Post
Hello.
Thanks!
beyond_illusions
beyond_illusions's Profile: beyond_illusions's profile on TechArena Computer Hardware Support Forums of India
View this thread: Start menu links issue. - Vista Help
TechArena Community - Technology and Computer Hardware Support Forums of India
Old 10-24-2009   #3 (permalink)
beyond_illusions
BIG THANKS!
that helped!
beyond_illusions
Old 10-24-2009   #4 (permalink)
You're most welcome.
BIG THANKS!
that helped!
beyond_illusions
Solved Start Menu links problem General Discussion
Start menu links General Discussion
Start Menu links Vista General
Unresponsive Start Menu Links Vista performance & maintenance
Custom links in start menu Vista General
