| | General system slow down issue - Vista Ultimate SP-2 (all current updates) - AMD 64 X2 6000+ - 4 gigs PC6400 RAM I am experiencing a general slow down of my Vista system, e.g., 5-30 seconds for applications to load, 5-10 seconds for a new tab to appear in IE8, applications displaying "not responding" while an operation is working such as saving an image or file, etc. This is isolated to Vista only. I have Windows 7 and XP installed (tri-boot) as well and they do not exhibit this problem. So, I have to conclude it is not hardware related. The system is squeaky clean; full scans with KAV 9.0.0.746 and Malwarebyte's Anti-malware. I've run both Chkdsk and SFC /scannow resulting in no change. Task Manager shows no unusual CPU usage nor Memory usage. Any ideas what may be causing this? I do not know when it started but it has been ongoing for a couple of months. Everything works but slowly. I've run out of ideas as to what to check. |
| | Re: General system slow down issue Hapkido wrote: Quote: > > - Vista Ultimate SP-2 (all current updates) > - AMD 64 X2 6000+ > - 4 gigs PC6400 RAM > > I am experiencing a general slow down of my Vista system, e.g., 5-30 > seconds for applications to load, 5-10 seconds for a new tab to appear > in IE8, applications displaying "not responding" while an operation is > working such as saving an image or file, etc. > > This is isolated to Vista only. I have Windows 7 and XP installed > (tri-boot) as well and they do not exhibit this problem. So, I have to > conclude it is not hardware related. The system is squeaky clean; full > scans with KAV 9.0.0.746 and Malwarebyte's Anti-malware. I've run both > Chkdsk and SFC /scannow resulting in no change. Task Manager shows no > unusual CPU usage nor Memory usage. > > Any ideas what may be causing this? I do not know when it started but it > has been ongoing for a couple of months. Everything works but slowly. > I've run out of ideas as to what to check. > Less than 20% and things start to slow; anything less than 10% and they crawl. G |
| | Re: General system slow down issue Thanks for replying... 96 gigs free on this 152 gig partition. "Bigguy" <bigguy@newsgroup> wrote in message news:7koj28F37bj95U1@newsgroup Quote: Quote: >> > > Less than 20% and things start to slow; anything less than 10% and they > crawl. > > > G > |
| General System Health Report Error - Please Help | General Discussion | |||
| General safety issue. | Vista security | |||
| system running slowly in general | Vista General | |||
| General System Performance Questions/Issues | Vista General | |||
| Post on Vista General unless your issue is specifically a setup problem. | Vista installation & setup | |||
