On a Vista machine Is there a way to reset the action of double-clicking on
a .jpg to mimic the behavior of right-clicking the file and selecting
preview?
preview?
"Wowbagger" <privacy, please> wrote in message
news:eR4ESP5YKHA.196@newsgroup
> on a .jpg to mimic the behavior of right-clicking the file and selecting
> preview?
Check the value of the 'default' key at
HKEY_CLASSES_ROOT\jpegfile\shell
It should show '(value not set)'., in the right pane. If not then modify the
default key in the right pane to remove whatever's there.
If that sounds a bit too tricky then post back and I'll attach a .reg file
that does the same.
Jon
"Jon" <Email_Address@newsgroup> wrote in message
news:ewc%23In6YKHA.196@newsgroupThat was set correct but a branch lower in the registry key I noted that the
> the default key in the right pane to remove whatever's there.
command to open was pointing to the WPG in \program files\ that doesn't work
very well instead of the WGP in \program files (x86)\ that does so I made
that tweak.
Now photos on C:\* open lightning-fast but photos on a network share are
still slower than molasses to open.
| Similar Threads | ||||
| double click? | jimmac542 | Vista General | 2 | 12 Jul 2008 |
| Enable one click instead of double click selection | genie616 | Vista installation & setup | 1 | 28 Aug 2007 |
| Single Click Instead Of Double Click | Port Admiral Haynes | Vista General | 2 | 28 Mar 2007 |
| No double click | Brett | Vista General | 2 | 07 Feb 2007 |
| hot to change mouse to single click instead of double click to ope | joseph bell | Vista hardware & devices | 1 | 14 Jun 2006 |
