Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista General
Vista - Sound Recorder
11-14-2009   #1 (permalink)
rmo555
Sound Recorder
Using the sound recorder, how do I save a file in the *.wav format. My
manual says I have a choice of WMA or WAV - but the recorder only gives
me WMA as the option.
11-14-2009   #2 (permalink)
Bob
Re: Sound Recorder
From a command prompt:
soundrecorder /file outputfile.wav
<rmo555@newsgroup> wrote in message
news:evjuf5due1pbvtk35brk45isugq31olkco@newsgroup
11-14-2009   #3 (permalink)
rmo555
Re: Sound Recorder
Is /file the name I give the original recording when I have to save it
as a *.wma?
11-14-2009   #4 (permalink)
Lu Powell
Re: Sound Recorder
"Bob" <bob@newsgroup> wrote in message
news:%23BRRgCZZKHA.1640@newsgroup
I tried that in Vista Home Premium. No matter what you name it, the file is
still WMA format.
11-14-2009   #5 (permalink)
Bob
Re: Sound Recorder
See this:
http://www.vista4beginners.com/Sound-Recorder
news:h7ouf5hq299fqpnvih3eqk2c1aauf8pare@newsgroup
> as a *.wma?
11-14-2009   #6 (permalink)
Bob D.
Re: Sound Recorder
From the help file it indicates Vista Home Premium saves as a WMA file and
other versions of Vista saves as a WAV file.
Bob
"Lu Powell" <lupowell@newsgroup> wrote in message
news:9BEB35D6-4EFE-427E-80D7-1D44F52F5339@newsgroup
> is still WMA format.
11-14-2009   #7 (permalink)
Lu Powell
Re: Sound Recorder
Yes, I read that, though I was still hoping. Thanks.
"Bob D." <bobd58@newsgroup> wrote in message
news:eGr$GFaZKHA.740@newsgroup
> Bob
11-15-2009   #8 (permalink)
rmo555
Re: Sound Recorder
OK, I installed Audacity - great tip. Thanks for the other responses
to my post also.
One more question: Since system sounds play immediately, what window
app plays them?
On Sat, 14 Nov 2009 21:58:31 -0500, "Bob" <bob@newsgroup> wrote:
Quote:
>See this:
>> as a *.wma?
11-15-2009   #9 (permalink)
Bob
Re: Sound Recorder
I don't believe there is a specific app but you can choose the sounds you
like for specific events.
http://www.microsoft.com/enable/trai...ta/sounds.aspx
news:j0a0g5tv74p8soand74pi468tvtqu1mmm3@newsgroup
> to my post also.
> app plays them?
Quote:
>>See this:
>>> as a *.wma?
>>>>> My
>>>>> gives
11-15-2009   #10 (permalink)
rmo555
Re: Sound Recorder
Doesn't there HAVE to be an app/applet to play sound files?
>> to my post also.
>> app plays them?
Quote:
>>>See this:
>>>> as a *.wma?
>>>>>> My
>>>>>> gives
 Sound Recorder problems?
Similar topics to: Sound Recorder
Sound Recorder Vista General
?????? Sound Recorder ???????????? Vista General
How to record sound clips or music using the sound recorder? Vista music pictures video
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
