I have had a serious problem with IE7 after installing Vista Ultimate (RTM)
in that while it will launch once, a second and any subsequent launch fails.
If I re-set IE7, I can again get one successful launch, but then the failures
resume.
After comparing the settings in HKLM\Software before and after the one
successful launch (after which IE7 will fail on launch) I got the hunch to
try unchecking the "Enable Protected Mode" box on the Security tab in
Internet Settings.
Sure, enough, IE7 worked 'normally' after turning it off. If I turn it on
again, though, IE7 fails as before and I have to reset it to get it working
again.
So I am looking for help/ideas/suggestions to try to resolve the problem of
why a second launch of IE7 on Vista Ultimate (RTM) after a reset fails if the
Enable Protected Mode box is checked.
Here is a comparison of HKLM/Software before and after the one successful
launch with Protected Mode enabled (after which it will fail until reset):
Comparing files HKLMswPrior.reg and HKLMSWPOST.REG
***** HKLMswPrior.reg
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Cryptography\RNG]
"Seed"=hex:a5,2b,14,0a,78,19,69,d4,c8,0a,f7,41,0f,c2,86,13,0d,d0,fb,d0,4f,6c,\
f6,e8,68,02,09,f4,9b,9e,12,e0,4b,42,33,89,c1,9f,25,04,95,2c,2f,fa,8b,f2,fc,\
db,b7,38,65,15,44,16,cf,e2,9c,da,93,1c,2f,ab,b7,29,90,cc,96,7c,86,e1,40,29,\
fb,d8,9f,36,6d,14,c7,cf
***** HKLMSWPOST.REG
"Seed"=hex:28,ca,8e,5b,0d,3a,a5,7e,f8,6b,38,eb,14,65,49,e6,65,30,3b,e8,7e,04,\
83,96,de,91,a2,c7,2c,bc,8d,5e,a8,10,d7,7a,58,95,bc,7c,64,5c,94,18,a3,5f,a1,\
a3,48,a9,65,97,c2,dd,a9,98,52,b2,83,76,e1,f4,4b,5a,d9,3a,d7,34,ec,05,2e,d1,\
d4,d8,d2,e3,a2,8a,a4,e9
"ProfileLoadTimeHigh"=dword:00000000
"RefCount"=dword:00000006
"RunLogonScriptSync"=dword:00000000
"RefCount"=dword:00000007
"LogNumber"=dword:00000041
"NotificationLogCheckPoint"=hex:a5,ef,00,00,00,00,00,00
"HistoryHashMapFile"="C:\\ProgramData\\Microsoft\\Search\\Data\\Applications\\Windows\\Projects\\SystemIndex\\SystemIndex.Hash.
"NotificationLogCheckPoint"=hex:38,fb,00,00,00,00,00,00
Thanks much for any help you might be able to offer! And have a Happy
Thanksgiving, too!
All the best,
will
William F. Zachmann
Canopus Research Inc.
http://www.canopusresearch.com
