Vista - Samsung 1740 will not print unless USB is plugged in, won't work..
Old 11-23-2006   #1 (permalink)
mike1650
wirelessly like it did in XP. It won't print anything, the says the port is
USB virtual
the print spooler service is running. It shows up in my printers on my
desktop on my wireless network but I can't print to it. Using Vista Ultimate
build 5744. Any ideas? Lost a rebate on something cause I couldn't print the
form, I couldn't even print to file. If I plug in the USB cable it works
fine. HELP
No Samsung ML-1740 printer support in Windows 7 Beta Drivers
Microphone doesn't work when plugged in Vista music pictures video
How does a print server work? Vista print fax & scan
Samsung 226BW with 8800GTS - Magictune doesn't work Graphic cards
Samsung mp3 player won't work Vista hardware & devices
