Vista - Vista Sidebar Problems
Old 11-30-2006   #1 (permalink)
Stormbringer_za
Hi
I have installed the official release of Vista and everything is fine.
But after a while and a few restarts, the Sidebar stops working, it
just disappears.
And if you try and start it again, nothing happens and also if you try
and install a gadget it give you an "Unspecified error".
Any advise will be appreciated.
Stormbringer_za
Stormbringer_za's Profile: http://forums.techarena.in/member.php?userid=19730
View this thread: http://forums.techarena.in/showthread.php?t=634023
http://www.techarena.in
Old 02-04-2007   #2 (permalink)
popsd23
RE: Vista Sidebar Problems
Sorry, but it was good to see your post as I am having the same issue..The
sidebar is gone!
"Stormbringer_za" wrote:
> Hi
> just disappears.
> Stormbringer_za
Old 02-05-2007   #3 (permalink)
Stormbringer_za
Re: Vista Sidebar Problems
Hi
I found in my case that is was when I installed an older version of SQL
that it decided to crash the sidebar.
Regards
Stormbringer_za
IE 8 caused Sidebar problems General Discussion
Windows Vista Sidebar problems Vista performance & maintenance
Windows Sidebar problems. Vista General
sidebar problems Vista General
Problems with gadgets for the sidebar Vista General
