Vista - RE: The 64-bit UPGRADE Question Remains...
Old 11-29-2006   #1 (permalink)
cvp
You missed the point. we are told that the Vista Upgrade product will not
allow the installation by booting from the dvd.
"dfeifer" wrote:
> You can not upgrade a 32 bit product to 64 bit. If that is your route, the
> only option you have is to install a fresh copy off of the vista install cd,
> and then use the settings and transfer wizard to tranfer your info from xp to
> vista.
The *Question* remains Vista General
The 64-bit UPGRADE Question Remains... Vista General
The #2 *Question* remains Vista General
RE: The 64-bit UPGRADE Question Remains... Vista General
