RB
Vista - Vista Upgrade Advisor Problem
06-08-2006   #1
Blue_Rival
I have downloaded and install the Windows Vista Upgrade Advisor Beta software
and have installed it on my home computer. My problem is after I launch the
software and select “Start system Scan” I receive a page cannot be found
error page. You know the one that tells you to check network settings – etc.
Well my network connection is fine and I have no trouble accessing any web
sites at all. Has anyone else experienced this and know how to get past this
error?
I use WinXP Pro SP2 w/ IE 7 beta1
Thanks
06-08-2006   #2
Zack Whittaker
Re: Vista Upgrade Advisor Problem
Try reinstalling the product - should fix it.
Zack Whittaker
ZackNET Enterprises: www.zacknet.co.uk
MSBlog on ResDev: www.msblog.org
Vista Knowledge Base: www.vistabase.co.uk
This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"Blue_Rival" <BlueRival@discussions.microsoft.com> wrote in message
news:34B07992-0A2D-425F-996E-77DFCEF7E4CD@microsoft.com...
>software
> the
> software and select "Start system Scan" I receive a page cannot be found
> error page. You know the one that tells you to check network settings -
> etc.
> this
> error?
> Thanks
06-08-2006   #3
Andre Da Costa [Extended64]
He did that. I would suggest downloading the application again. Also, it
could be a conflict with IE 7.
Andre
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Zack Whittaker" <admin@zacknet.co.uk> wrote in message
news:e7Ip4UyiGHA.1276@TK2MSFTNGP03.phx.gbl...
> Zack Whittaker
> not
> that up!
>>software
>> the
>> etc.
>> web
>> this
>> error?
>> Thanks
06-08-2006   #4
Blue_Rival
I have re-installed it 2x and also tried running the repair option.
I guess I will try removing IE7 Beta 1 unless anyone else has an idea?
> Andre
> > Zack Whittaker
> > » ZackNET Enterprises: www.zacknet.co.uk
> > » MSBlog on ResDev: www.msblog.org
> > » Vista Knowledge Base: www.vistabase.co.uk
> > » This mailing is provided "as is" with no warranties, and confers no
> > not
> > that up!
> >>software
> >> the
> >> etc.
> >> web
> >> this
> >> error?
> >> Thanks
06-08-2006   #5
Travis King
I use IE7 beta 2 on my computer and it works fine.
news50EDF11-291C-4AB0-8009-4C3AEF57AD0C@microsoft.com...
>> Andre
>> > Zack Whittaker
>> > and
>> > not
>> > cleared
>> > that up!
>> >>software
>> >> launch
>> >> the
>> >> found
>> >> settings -
>> >> etc.
>> >> web
>> >> past
>> >> this
>> >> error?
>> >> Thanks
06-08-2006   #6
He is using IE 7 Beta 1.
Andre
"Travis King" <Anonymous@none.com> wrote in message
news:%230PpfMziGHA.960@TK2MSFTNGP05.phx.gbl...
>>> Andre
>>> > Zack Whittaker
>>> > and
>>> > not
>>> > cleared
>>> > that up!
>>> >>software
>>> >> launch
>>> >> the
>>> >> found
>>> >> settings -
>>> >> etc.
>>> >> any
>>> >> web
>>> >> past
>>> >> this
>>> >> error?
>>> >> Thanks
06-08-2006   #7
Travis King
Yeah, I was aware of that... Kind of why I brought it up. ; )
"Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message
news:OZXtYSziGHA.1940@TK2MSFTNGP02.phx.gbl...
> Andre
>>>> it
>>>> Andre
>>>> > Zack Whittaker
>>>> > and
>>>> > not
>>>> > cleared
>>>> > that up!
>>>> >>software
>>>> >> launch
>>>> >> the
>>>> >> found
>>>> >> settings -
>>>> >> etc.
>>>> >> any
>>>> >> web
>>>> >> past
>>>> >> this
>>>> >> error?
>>>> >> Thanks
RB
Similar Threads for: Vista Upgrade Advisor Problem
Solved Hi Upgrade Advisor Problem General Discussion
vista upgrade advisor Vista General
Windows Vista Upgrade Advisor run problem Vista General
Vista Upgrade Advisor says: Vista General
Upgrade Advisor Installatio Problem Vista installation & setup
Designer Media Ltd
