Hi Keith,
This may answer some questions:
http://support.microsoft.com/kb/917607
Essentially, the .hlp format is no longer supported, and your company may
need to redirect its efforts to a different one. There will be a download
for your clients that need it to support this older format as an interim
fix. The free distributable it refers to is not yet available, but should be
early next year.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help -
www.rickrogers.org
"Keith G Hicks" <krh@comcast.net> wrote in message
news:ueFY21bGHHA.1216@TK2MSFTNGP05.phx.gbl...
> I'm not an expert on this and I have a question. An application we've been
> developing for the past couple of years has a help file (chm primarily)
> that
> one of our people created that makes extensive use of context sensitive
> help
> (using an hlp file) that pops up formatted (bold, italics, hyperlinks,
> etc)
> help boxes (not the entire help file) in key areas so the user can get a
> quick idea about something without having the entire help open up. A lot
> has
> gone into this. We recently heard that Vista was going to support this to
> some degree but that the formatting would not appear (something to that
> effect). Some of the newsgroup posts indicate soemthing about a potential
> free download from MS to better support hlp help. How does all this affect
> the hlp help boxes I'm talking about? I'm not getting a clear picture
> about
> all of this yet. My customers like the ability to pop up these little
> boxes
> rigth where they need them and the formatting makes things much clearer
> than
> just plain text. It seems like going backwards to eliminate this option.
> Thanks,
> Keith
