| | Help with folders Ok, i like vista but I have 2 problems with it. I am trying to get the folders the way I want them, but cannot seem to find the options i need. First, I want to remove the catagories in all of the folders (pic 2). I am able to uncheck all of the boxes except for the name. Since I use icno view it doesn't do me any good to have them there. The second problem is that I want to use "Classic Icons" for my folders (pic 1). There is an option on my desktop for that, but not in the folders. Is there a way to get that? |
| Copied Folders.dbx & all folders from Outlook Express...Winmail do | Vista mail | |||
| Renamed Folders Revert to Previous Names, Cannot Move Folders - FOLDERS ONLY | Vista file management | |||
| Help - How to select all folders or group of folders, and make them 'Mark as Read' ? | Live Mail | |||
| Moving User Folders Corrupts Desktop, Favorites, Contacts and Documents Folders | Vista General | |||
| How to count the total files under c:\abc\<* folders>\out where <* folders> are many folders? | PowerShell | |||
