Vista Tutorial - Multi Monitor Backgrounds
Old 12-13-2006   #1 (permalink)
OtIs@7&2
Guest
Is it possible in Vista to have different backgrounds on different monitors.
Under xp i was able to install the nvidia drivers and change this. When i
install those drivers now i dont get the same options. I am running Dual SLI
7800 GT with one 19" (Acer AL1931) and Two Dell 19" ???. Yea yea i know sli
dosent work on multi monitors. didnt know that until i spent the 1400 bucks.
But they do work well in single mode on multi screens. ANY SUGGESTIONS ON THE
BACKGROUND THING
Old 12-13-2006   #2 (permalink)
Colin Barnhorst
Guest
Re: Multi Monitor Backgrounds
They are still beta drivers and not full-featured. Wait for the final
towards launch day.
"OtIs@7&2" <OtIs@7&2@discussions.microsoft.com> wrote in message
news:5BBD844F-C932-4418-8EDE-7DAFDEE55293@microsoft.com...
> monitors.
> SLI
> sli
> bucks.
> THE
> BACKGROUND THING
Old 12-14-2006   #3 (permalink)
Synapse Syndrome
Guest
> monitors.
> SLI
> sli
> bucks.
> THE
> BACKGROUND THING
I'd normally suggest Ultramon, except that particular feature isn't yet
working with Vista. Hopefully, the long awaited v3 will be out soon. Most
things work well with Vista, and I can't do without the second task bar that
it adds. Unfortunately it is not transparent yet.
www.ultramon.com
ss.
Old 12-14-2006   #4 (permalink)
Tekguru (Daron Brewood)
Guest
I use UltraMon to achieve this.
MS-MVP/Mobile Devices
Webmaster: UKs largest Pocket PC Site
http://www.4WinMobile.com
Old 12-14-2006   #5 (permalink)
Synapse Syndrome
Guest
"Tekguru (Daron Brewood)" <tekguru@tekguru.co.uk> wrote in message
news:fynyygliu0kc$.dlg@tekguru.co.uk...
>> monitors.
Ah, only just realised that feature does work in Vista. I think it may not
have in earlier builds.
ss.
Old 12-14-2006   #6 (permalink)
OtIs@7&2
Guest
Thanks for the help it works great!!
> >> monitors.
> ss.
Old 12-14-2006   #7 (permalink)
Guest
It did as I've been using it in Vista RC1 through to RTM, it was working in
the last three UltraMon versions.
Multi Monitor help Graphic cards
Multi-Monitor Enhancers Software
Vista multi monitor bug!!! Vista performance & maintenance
Vista multi monitor bug!!! Vista General
Dual Monitor - Seperate Backgrounds Vista General
