| | Network problem on Wakeup from Hibernation Hello. I have Windows Vista Ultimate and I noticed that my network connection is unusable. I have to disable and re-enable my NIC from Network properties to keep it going again. Has anyone experienced this? |
| | Re: Network problem on Wakeup from Hibernation I have to say yes. I first experienced this upon first build. I have also experienced this under XP SP-2. However only on my wireless connection. I havent searched for or cared about a fix as it was simply turning the device off and back on again. "C Dot C" <nobody@nowhere.com> wrote in message news:5A937238-DF31-4672-96B4-3F0A4D961DBC@microsoft.com... > Hello. > > I have Windows Vista Ultimate and I noticed that > my network connection is unusable. I have to disable > and re-enable my NIC from Network properties to > keep it going again. > > Has anyone experienced this? |
| | Re: Network problem on Wakeup from Hibernation Which network card? Wireless? Drivers? -- Nancy Ward Windows Live Butterfly Windows Live MVP 2003-2006 > "C Dot C" <nobody@nowhere.com> wrote in message news:5A937238-DF31-4672-96B4-3F0A4D961DBC@microsoft.com... > Hello. > > I have Windows Vista Ultimate and I noticed that > my network connection is unusable. I have to disable > and re-enable my NIC from Network properties to > keep it going again. > > Has anyone experienced this? |
| | Re: Network problem on Wakeup from Hibernation Thank you all for responding. I think Vista has updated the driver on my onboard 10/100 NIC because I have hibernated my machine several times today and in all instances, the network connection was active after hibernation. Sorry. I'm testing Windows Vista Ultimate RTM on an old Dell Optiplex. "Nancy Ward" <nlward@pshawus.com> wrote in message news:eom3t86HHHA.420@TK2MSFTNGP02.phx.gbl... > Which network card? Wireless? Drivers? > > -- > Nancy Ward > Windows Live Butterfly > Windows Live MVP 2003-2006 >> > "C Dot C" <nobody@nowhere.com> wrote in message > news:5A937238-DF31-4672-96B4-3F0A4D961DBC@microsoft.com... >> Hello. >> >> I have Windows Vista Ultimate and I noticed that >> my network connection is unusable. I have to disable >> and re-enable my NIC from Network properties to >> keep it going again. >> >> Has anyone experienced this? > > |
| Network problem after hibernation - solved! | Network & Sharing | |||
| Failure to find DVD burner on wakeup from sleep or hibernation | Vista hardware & devices | |||
| No Network connection after wakeup | Network & Sharing | |||
| WAKEUP problem.... | Vista General | |||
| Vista ridiculously unresponsive after hibernation wakeup. | Vista General | |||
