Vista Tutorial - Remote Desktop doesnt work from outside network
Old 12-15-2006   #1 (permalink)
Paul
Guest
I have upgraded from WinXP, where I have been using a non standard port for
RDP for years. I have a D-Link router, where I have opened up that port. To
verify, I can telnet to my external IP on that port and it comes through.
Anyways, I now have Vista, and I can RDP from my computer, to my computer
using the LAN IP address and custom port. It tells me, as expected, that I
am already logged into the console - so it appears to connect just fine.
However, when I try connecting from my computer to the external address, it
tells me my credentials dont work. Whats funny, is it will show the
appropriate logon graphic for my user account. If I try another account, it
will change to the appropriate logon graphic for that account. So it seems
to be connecting to my computer and getting so far....
In both instances I use my custom port for connection, and I use the format
computername\username to login. I have created a custom firewall rule for
all networks, to allow my custom port in for ANY.
The windows firewall doesnt show much, but logging successful and dropped, I
only see allowed connections on my custom port, as expected.
If I were to guess, I would think its some sort of authentication issue,
like it wont allow authentication outside my LAN? Does anybody have any tips?
Old 12-15-2006   #2 (permalink)
Mike
Guest
RE: Remote Desktop doesnt work from outside network
Paul, have you tried editing the RDP and under "Advanced" selecting "Always
connect, even if authentication fails"?
Give it a go!
Regards,
Mike
Remote Desktop clipboard doesn't work Network & Sharing
Shortcut on desktop for a network mapped drive doesnt work Vista General
Network Connection doesnt work but worked before Vista General
Vista Remote Desktop credentials do not work Vista networking & sharing
