| | Problem... After I installed Vista, it ran great... HOWEVER, now I can't open the mail utility and I keep getting a message that says the file system is corrupt, please run chkdsk utility... I have scheduled a chkdsk for boot numerous times, but it won't run... what do I do???? Josh |
| | Re: Problem... Click Start > All Programs > Accessories > right click Command Prompt > on the context menu click "Run as Administrator" > type in CHKDSK /F -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "Joshua Edwards" <jedwards81@comcast.net.DONOTSPAM> wrote in message news:e142157542d88c8596383b521b8@msnews.microsoft.com... > After I installed Vista, it ran great... HOWEVER, now I can't open the > mail utility and I keep getting a message that says the file system is > corrupt, please run chkdsk utility... I have scheduled a chkdsk for boot > numerous times, but it won't run... what do I do???? > > Josh > > |
| | Re: Problem... Andre... Got it fixed.... thanks. Josh Andre Da Costa [Extended64] wrote: > Click Start > All Programs > Accessories > right click Command Prompt > on > the context menu click "Run as Administrator" > type in CHKDSK /F |
| | Re: Problem... You are welcome Josh. ![]() -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "cnorgangrad" <jedwards81@comcast.net.DONOTSPAM> wrote in message news:eJk$id3iGHA.960@TK2MSFTNGP05.phx.gbl... > Andre... > Got it fixed.... thanks. > > Josh > > > Andre Da Costa [Extended64] wrote: >> Click Start > All Programs > Accessories > right click Command Prompt > >> on the context menu click "Run as Administrator" > type in CHKDSK /F |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
