Vista - Clearing IP settings: duplicate ip settings and blank ip settings
Old 12-16-2006   #1 (permalink)
Tech_vs_Life
I have a local network adapter, and whenever I check the property sheet for
its ipv4 settings, it is always blank for the user-defined ip and subnet
mask, even after adding them in. (that is, after adding them in and going
back to check, the settings are blank). (Default gateway is fine).
When I run ipconfig, it shows two ip addresses for the adapter (x.x.x.124
and x.x.x.129).
Any suggestions? I've tried resetting the adapter, deleting the driver, and
a few other things, to no avail. is there a utility that can be downloaded
that can diagnose this? Or a registry setting to delete?
Thanks.
Old 12-16-2006   #2 (permalink)
Some Guy in Kirkland
Re: Clearing IP settings: duplicate ip settings and blank ip settings
sss
"Tech_vs_Life" <limited@newsgroups.nospam> wrote in message
news:45A7EAEC-103C-42AF-B0F0-14E03088D25F@microsoft.com...
> and x.x.x.129).
> and a few other things, to no avail. is there a utility that can be
> downloaded that can diagnose this? Or a registry setting to delete?
> Thanks.
Old 12-16-2006   #3 (permalink)
Tech_vs_Life
I didn't understand your response.
"Some Guy in Kirkland" <mallyman@comcast.net> wrote in message
news:F9DF3298-AEE4-4013-8B1B-4E56FAF784D2@microsoft.com...
> sss
Old 12-16-2006   #4 (permalink)
neither do i.. . i actually fired off a delete request for that post..
was messing with my login id...
r
news:AD554A16-B2E0-47BD-A224-9FD1DA58A8FF@microsoft.com...
>> sss
User Settings Disappearing; Monitor Settings Unstable; Desktop Search Overtakes System; Laptops Unusable Vista General
Cannot open Theme Settings, Display Settings, Screen Saver Settings, etc Vista performance & maintenance
Application Settings user settings storage directory .NET General
Folder settings in Vista keep going back to the default settings Vista General
Clearing IP settings: duplicate ip settings and blank ip settings Vista networking & sharing
