Vista - Vista RTM Control Panel Problem
Old 12-22-2006   #1 (permalink)
yoshi
I have a weird problem. When I click the Start logo and Control Panel, it
does nothing. The Control Panel will not show up BUT if I create a short cut
on my desktop, it works.
Has anyone seen this?
It's Vista RTM
Thanks,
Yosh
Old 12-22-2006   #2 (permalink)
Mike
Re: Vista RTM Control Panel Problem
"yoshi" <yoshi@nospam.com> wrote in message
news:A80F1E02-77FA-4ACA-A4E3-62A0A53213E3@microsoft.com...
>cut on my desktop, it works.
Do you have it set to display as a link or as a menu? If menu (little
arrow) and it pops up as a menu, then clicking it doesn't work.
If you have it set to display as a link and it doesn't work, then I have no
idea.
Mike
Old 12-22-2006   #3 (permalink)
Daze N. Knights
I'd be interested in knowing how one creates a shortcut for the control
panel on one's desktop. What is the control panel's executable file?
> it does nothing. The Control Panel will not show up BUT if I create a
> short cut on my desktop, it works.
> It's Vista RTM
> Thanks,
> Yosh
Old 12-22-2006   #4 (permalink)
Mike
"Daze N. Knights" <Daze@microchip.com> wrote in message
news:exmPwxeJHHA.3668@TK2MSFTNGP02.phx.gbl...
Right click it on the Start menu. Show on desktop is an option.
Mike
Old 12-22-2006   #5 (permalink)
Alexander Suhovey
It's "control.exe"
And most of Control Panel applets are .CPL files under c:\windows\system32.
You can run them directly or from cmooand line/shortcut:
C:\>dir /b %windir%\system32\*.cpl
appwiz.cpl
bthprops.cpl
collab.cpl
desk.cpl
Firewall.cpl
hdwwiz.cpl
inetcpl.cpl
infocardcpl.cpl
intl.cpl
irprops.cpl
joy.cpl
main.cpl
mmsys.cpl
ncpa.cpl
nvcpl.cpl
powercfg.cpl
sysdm.cpl
TabletPC.cpl
telephon.cpl
timedate.cpl
wmdConn.cpl
wscui.cpl
C:\>
Alexander Suhovey
Old 12-22-2006   #6 (permalink)
Synapse Syndrome
"Alexander Suhovey" <asuhovey@gmail.com> wrote in message
news:CCF3F98B-9B83-4A77-9529-5B4E32DB4B00@microsoft.com...
> It's "control.exe"
> c:\windows\system32. You can run them directly or from cmooand
> line/shortcut:
My Control Panel only shows half the applets and it takes a few seconds for
the rest to display. This is really annoying, considering I have a fast
system with RAID 0 drives. Do you know how to make the rest appear like the
first batch? They really should be Superfetched or something.
ss.
Old 12-23-2006   #7 (permalink)
Lang Murphy
You doing Vista or Classic view in CP? I'm running Vista view here and all
pop at the same time, no delays.
Lang
"Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message
news:%23e1UG9hJHHA.3872@TK2MSFTNGP06.phx.gbl...
>> It's "control.exe"
>> line/shortcut:
> for the rest to display. This is really annoying, considering I have a
> fast system with RAID 0 drives. Do you know how to make the rest appear
> like the first batch? They really should be Superfetched or something.
> ss.
Old 12-23-2006   #8 (permalink)
Synapse Syndrome
"Lang Murphy" <lang_murphy@hotmail.com> wrote in message
newsA71DB87-FFAD-4967-A93C-242E69F750F8@microsoft.com...
Classic View. I don't understand why anybody that is familiar with all the
applets would use anything else.
ss.
Old 12-23-2006   #9 (permalink)
Alexander Suhovey
>> It's "control.exe"
>> line/shortcut:
Sorry, ss. Don't have an answer to this one.
I've seen this behaviour on relatively slow systems while my last setup with
WEI 5.2 (HDD 5.9) doesnt have this problem. So it can be performance issue
that can be sloved by hw upgrade.
Also, which view do you use in Control Panel? If it is one of thumbinal
views (Extra Large, Large, Medium or Small Icons), try to change to List or
Table View to see if it solves the issue.
Alexander Suhovey
Old 12-24-2006   #10 (permalink)
Lang Murphy
Well... I changed the CP Start menu entry to show as a menu so it pops
pretty much like classic view in CP itself... so I don't really open CP
itself anymore...
Lang
news:%23jgTOlpJHHA.2232@TK2MSFTNGP02.phx.gbl...
>> all pop at the same time, no delays.
> the applets would use anything else.
> ss.
Windows Vista Home Premium Ed., Control Panel will not open problem. Any suggestions for fix? Vista performance & maintenance
vista not displaying problem and reports control panel Vista performance & maintenance
HELP - Vista Control Panel problem + other strange things Vista General
Vista Control Panel Problem Vista General
control panel problem Vista General
