Vista - Help Installing XNA
Old 12-24-2006   #1 (permalink)
Keeep Out
Help Installing XNA
When ever I try installing Microsoft XNA Game Studio Express It stops
installing when it says "Registering project templates". This is what it
looks like: http://i13.photobucket.com/albums/a2...t/Untitled.jpg
I am on Windows Vista RC2. I have allready installed Microsoft Visual C#
2005 Express Edition but the XNA part wont install. Their website says it
should work with Vista but it doesnt for me.
Old 12-24-2006   #2 (permalink)
Rick Rogers
Re: Help Installing XNA
Did you start by right clicking the setup file and choosing "run as
administrator". Without elevated privileges, many installers will fall over
and fail.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Keeep Out" <KeeepOut@discussions.microsoft.com> wrote in message
news:72C3B237-646B-41F1-930D-5AC6D0A5DD3E@microsoft.com...
Old 12-24-2006   #3 (permalink)
Keeep Out
There isnt an option to run as an administrator for it because it is a setup
file. Any other ideas for me? please help
"Rick Rogers" wrote:
> Hi,
> and fail.
> Best of Luck,
Old 12-24-2006   #4 (permalink)
Rick Rogers
I'm referring to the actual setup.exe or .msi file that is run. Don't use an
autorun routine, explore via Windows Explorer the media containing the setup
files for it.
Best of Luck,
news:4A9417F1-0763-418F-814C-33B3844A1D47@microsoft.com...
> setup
>> Hi,
>> over
>> and fail.
>> Best of Luck,
>> > it
>> > looks like:
>> > C#
>> > it
Old 12-25-2006   #5 (permalink)
Keeep Out
I dont understand. please explain in detail to me. it is an msi file.
> Hi,
> files for it.
> Best of Luck,
> > setup
> >> Hi,
> >> over
> >> and fail.
> >> Best of Luck,
> >> > it
> >> > looks like:
> >> > C#
> >> > it
Old 12-25-2006   #6 (permalink)
Rick Rogers
Don't let the setup autorun from the installation media. Open Windows
Explorer to the media (CD or folder created after expanding a download).
Right click the .msi file, use "run as administrator".
Best of Luck,
news52EC20D-7729-412B-BFC4-95F3598B979F@microsoft.com...
>> Hi,
>> an
>> setup
>> files for it.
>> Best of Luck,
>> > setup
>> >> Hi,
>> >> over
>> >> and fail.
>> >> Best of Luck,
>> >> > stops
>> >> > what
>> >> > it
>> >> > looks like:
>> >> > Visual
>> >> > C#
>> >> > says
>> >> > it
Old 12-25-2006   #7 (permalink)
Keeep Out
Once again, there is no option to run as administrator. I saved it to my
desktop and there is no option when I right click it. Someone told me to
start it from an administrator command prompt but I am not sure what to type
(it is called xnagse_setup.msi and is located on my desktop). can you please
help me? thank you
> Hi,
> Best of Luck,
> >> Hi,
> >> an
> >> setup
> >> files for it.
> >> Best of Luck,
> >> > setup
> >> >> Hi,
> >> >> over
> >> >> and fail.
> >> >> Best of Luck,
> >> >> > stops
> >> >> > what
> >> >> > it
> >> >> > looks like:
> >> >> > Visual
> >> >> > C#
> >> >> > says
> >> >> > it
Old 12-25-2006   #8 (permalink)
Colin Barnhorst
Click on the Start Orb, type "cmd" (do not hit enter), right click on the
Command icon in the menu above, choose Add to Quick Launch. Then right
click on the Command icon you placed on the QL and select Properties. The
Shortcut tab on the Properites page will display. Click the Advanced button
ant then put a checkmark in the Run As Administrator box. OK out of
Properites. Now you can run the command prompt with administrator rights
anytime you want. Running the msi file should work now.
news:93622D73-09C6-408C-94A1-7F30FBDB3A3D@microsoft.com...
> type
> please
> help me? thank you
>> Hi,
>> Best of Luck,
>> >> Hi,
>> >> use
>> >> an
>> >> setup
>> >> files for it.
>> >> Best of Luck,
>> >> > a
>> >> > setup
>> >> >> Hi,
>> >> >> fall
>> >> >> over
>> >> >> and fail.
>> >> >> Best of Luck,
>> >> >> > stops
>> >> >> > what
>> >> >> > it
>> >> >> > looks like:
>> >> >> > Visual
>> >> >> > C#
>> >> >> > says
>> >> >> > it
Old 12-26-2006   #9 (permalink)
Rick Rogers
An alternate method to Colin's:
Click start, type CMD. In the menu you should now see the command prompt at
the top. Right click this and choose 'run as administrator'. It should
prompt for permission (UAC) to run. The prompt will be at the
C:\Windows\system32 folder, type: "cd %userprofile%\desktop" (no quotes) and
hit <enter>. Now type: "xnagse_setup.msi" (again, no quotes) and hit
<enter>. This should run the installer with the necessary elevated
privileges.
Best of Luck,
> type
> please
> help me? thank you
>> Hi,
>> Best of Luck,
>> >> Hi,
>> >> use
>> >> an
>> >> setup
>> >> files for it.
>> >> Best of Luck,
>> >> > a
>> >> > setup
>> >> >> Hi,
>> >> >> fall
>> >> >> over
>> >> >> and fail.
>> >> >> Best of Luck,
>> >> >> > stops
>> >> >> > what
>> >> >> > it
>> >> >> > looks like:
>> >> >> > Visual
>> >> >> > C#
>> >> >> > says
>> >> >> > it
Old 12-26-2006   #10 (permalink)
Keeep Out
yes, that did start the setup. but it still stopped working at the end like
before. if there is anything elses I could try, please post.
> Hi,
> privileges.
> Best of Luck,
> > type
> > please
> > help me? thank you
> >> Hi,
> >> Best of Luck,
> >> >> Hi,
> >> >> use
> >> >> an
> >> >> setup
> >> >> files for it.
> >> >> Best of Luck,
> >> >> > a
> >> >> > setup
> >> >> >> Hi,
> >> >> >> fall
> >> >> >> over
> >> >> >> and fail.
> >> >> >> Best of Luck,
> >> >> >> > stops
> >> >> >> > what
> >> >> >> > it
> >> >> >> > looks like:
> >> >> >> > Visual
> >> >> >> > C#
> >> >> >> > says
> >> >> >> > it
installing and re-installing cs3 on vista Software
installing Vista installation & setup
installing windows xp after installing vista Vista installation & setup
installing Vista General
Help Installing Pre-RC1 Vista installation & setup
