Reformat, fresh start?
  1. #1
    Tim Scott Mathews Guest
    I'll almost certainly want to move to Vista when it arrives on the shelves
    in late January. I had thought as it's a totally new OS during in stall it
    would "want" to reformat my hard drive but I see so much about both dual
    boot and upgrading that I'm not sure of what to expect and plan for. Will I
    be given some options during install as to how I wish to procede regarding
    any and everthing already on my system?
    If everthing currently installed can remain and the installation is more
    like an upgrade, is this one of those things one can do but often causes
    major headaches? I'd much prefer to reformat and reinstall any programs I
    use than have headaches with endless tweaking if I choose to "upgrade"
    rather than complete reformat/install.
    Thoughts, anyone?
    Thanks
    Tim
  2. #2
    Jeff Gaines Guest
    Re: Reformat, fresh start?
    On 28/12/2006 in message <1aOkh.101419$hn.40949@edtnps82> Tim Scott
    >it would "want" to reformat my hard drive but I see so much about both
    >dual boot and upgrading that I'm not sure of what to expect and plan for.
    >Will I be given some options during install as to how I wish to procede
    >regarding any and everthing already on my system?
    >I use than have headaches with endless tweaking if I choose to "upgrade"
    The Vista installation is different in a couple of key ways.
    If you buy an upgrade then you must install it from within a qualifying,
    activated OS. Although you can boot from the DVD you can't install from it
    (you can carry out repairs). A full version will allow you to install from
    the booted DVD and format the install partition.
    The actual installation process is different in that it appears to use a
    lot of images. It will tuck your existing apps out of the way, install
    itself, then pull the old apps back in (I am sure somebody will be able to
    give a more scientific explanation). Many people seem to believe that this
    gives you a 'clean' install even though the drive won't be formatted.
    It would be worthwhile reading this group for a while before you proceed.
    I have many apps that will not run on Vista, the potential cost of
    upgrading them is not worthwhile as far as I am concerned but you may well
    have a different view.
    Jeff Gaines
  3. #3
    Chad Harris Guest
    Tim--
    If I were you, I'd buy a full version and dual boot for a while. This
    enables you to keep XP intact, and you need only move the files and folders
    you want to. You can get used to Vista, and add apps to Vista one by one.
    I haven't run into the app that won't work on Vista for me, but I'm sure
    there are many out there given the slowness of some 3rd party companies to
    adapt to Vista waiting for I'm not sure what.
    Vista Ultimate Install Screens
    http://www.windowsvista.windowsreins...whdd/part1.htm
    Bios Guide
    http://www.windowsreinstall.com/articles/bios/XP
    You can access the files on your desktop from Vista with a simple shortcut
    that would be Vista Drive\Documents and Settings\Tim's Profile\Desktop and
    copy or move any you want to. This saves time and space if you dual boot.
    You just need to have a space that is adequate for what you'll be adding to
    Vista if you elect to do that. You can target the Vista installation to
    that space when you are in setup by clicking on Advanced on the screen or
    two after the language screen. 20-40 GB should do this for you, unless you
    are going to install many more apps then alot space accordingly.
    CH
    "Tim Scott Mathews" <nospam@nospam.ca> wrote in message
    news:1aOkh.101419$hn.40949@edtnps82...
    > Thoughts, anyone?
    > Thanks
    > Tim
  4. #4
    Colin Barnhorst Guest
    If you want to format first and then install Vista then buy the full
    edition. Upgrade editions can only be installed on a machine already
    running a legacy Windows. Unless you are just gaming and surfing the net,
    I do not recommend dual booting with XP. You have been reading threads
    about this already. Booting into XP causes you to lose many of the recovery
    capabilities of Vista. Search on this newsgroup on "volsnap.sys" to get
    further info.
    > Thoughts, anyone?
    > Thanks
    > Tim
  5. #5
    Lang Murphy Guest
    Some of the smartest guys in this NG have already spoken to the meat of your
    questions. I will now add my two cents...
    I always do a "bare metal" install with a new OS. Vista lets you delete
    partitions and start anew. When I move to Vista on my home PC, that's what
    I'll do.
    But... I'm not sure WHEN I'll move to Vista on my home PC. I've got too many
    apps with which I think I'll have problems. Of main concern are the utility
    apps I've purchased to allow me to get my legitimately purchased media onto
    my iPod. ImToo DVD to iPod converter being the major app. So... point being
    that you need to do some homework on your apps and HW -prior to- moving to
    Vista. Don't assume that everything that worked in W2K/XP will work in
    Vista. You'll see that in this NG every day: "Hey! My Periwinkle-Flotsam
    doesn't work in Vista. Worked fine in XP. What's up with that?" Uh... new
    OS? Need new drivers? Need an update to your app?
    Lang
    > Thoughts, anyone?
    > Thanks
    > Tim
  6. #6
    Jeff Guest
    To Tim,
    (sorry Lang)
    I may not be smart or nothin,
    cuz I deleted the original thread,but
    trust me, what Colin and Lang have said is dead on.
    They may not know it, but I've tested Vista reformatting WAY too many times
    to count-could be a Vista format mvp-lol
    And their advice is correct,
    do yourself a favor,
    install-don't upgrade-if you can afford too.
    (faster actually and less potential headaches than an upgrade)
    I've found, just by habit-that I do both-delete and format a partition.
    I have just one HD and partition,so I've just done this by habit-may not
    make a diff,but I do both.
    And simple stuff, like always right click-run as admin, helps when
    installing(if possible)
    Also, along with a good AV-(I personally like AVAST-free and nice), make
    sure to install the correct Java.
    It's Java JRE 6-it'll help with legacy apps rendering correctly with Vista.
    http://java.sun.com/javase/downloads/index.jsp (1/2 way down the page)
    Other than that-go for it-and remember-like Lang said-much stuff will
    work-but this o.s. is new territory-so some might not.
    (Lang-you're an iPodista- :-0 rofl)
    My one cent.
    Jeff
    "Lang Murphy" <lang_murphy@hotmail.com> wrote in message
    news:5C452F29-B560-498F-A006-280148E6ED47@microsoft.com...
    > your questions. I will now add my two cents...
    > I'll do.
    > many apps with which I think I'll have problems. Of main concern are the
    > utility apps I've purchased to allow me to get my legitimately purchased
    > media onto my iPod. ImToo DVD to iPod converter being the major app. So...
    > point being that you need to do some homework on your apps and HW -prior
    > to- moving to Vista. Don't assume that everything that worked in W2K/XP
    > will work in Vista. You'll see that in this NG every day: "Hey! My
    > Periwinkle-Flotsam doesn't work in Vista. Worked fine in XP. What's up
    > with that?" Uh... new OS? Need new drivers? Need an update to your app?
    > Lang
    >> shelves in late January. I had thought as it's a totally new OS during
    >> in stall it would "want" to reformat my hard drive but I see so much
    >> about both dual boot and upgrading that I'm not sure of what to expect
    >> and plan for. Will I be given some options during install as to how I
    >> wish to procede regarding any and everthing already on my system?
    >> Thoughts, anyone?
    >> Thanks
    >> Tim
  7. #7
    Chad Harris Guest
    Ipod presents no problems with Vista RTM or any other build prior to it in
    my experinece Lang. But I don't have any experience with the ImTooDVD to
    Ipod converter. I'd be inclined to go for it, and try to get it to work but
    every app could be different. In general, I have all my apps working on
    Vista that I've tried, but that's a long list and I haven't tried every one.
    Like most people I have apps that I thought I would use that I haven'g
    gotten around to in XP.
    For sure, despite the growing compatibility lists, some 3rd parties and some
    driver manufacturers are waiting around to the spring of 2007.
    CH
    > I'll do.
    > Lang
    >> Thoughts, anyone?
    >> Thanks
    >> Tim
  8. #8
    Lang Murphy Guest
    No apologies necessary, dude!
    Happy New Year!
    Lang
    "Jeff" <S.Cerevisiae@duh.edu> wrote in message
    news:%23b3mRJxKHHA.536@TK2MSFTNGP02.phx.gbl...
    > To Tim,
    > (sorry Lang)
    > times to count-could be a Vista format mvp-lol
    > Vista.
    > My one cent.
    > Jeff
    >> what I'll do.
    >> So... point being that you need to do some homework on your apps and
    >> HW -prior to- moving to Vista. Don't assume that everything that worked
    >> in W2K/XP will work in Vista. You'll see that in this NG every day: "Hey!
    >> My Periwinkle-Flotsam doesn't work in Vista. Worked fine in XP. What's up
    >> Lang
    >>> programs I use than have headaches with endless tweaking if I choose to
    >>> "upgrade" rather than complete reformat/install.
    >>> Thoughts, anyone?
    >>> Thanks
    >>> Tim
  9. #9
    Lang Murphy Guest
    Yeah... just "a-scared" of losing the ability to carry on in "business as
    usual" mode.
    Gotta try installing this stuff on a skunk box to see if it works. Just a
    matter of time and effort... shoot, I'm on vacation now... jes' sittin' at
    home but it's been years since I enjoyed working on my personal PC's, so
    I'll wait until the code's released and, one hopes, drivers and updates are
    released also...
    Lang
    "Chad Harris" <fixvista-itneedsit.net> wrote in message
    news:%23RVw4S6KHHA.1248@TK2MSFTNGP02.phx.gbl...
    > but every app could be different. In general, I have all my apps working
    > on Vista that I've tried, but that's a long list and I haven't tried every
    > one. Like most people I have apps that I thought I would use that I
    > haven'g gotten around to in XP.
    > some driver manufacturers are waiting around to the spring of 2007.
    > CH
    >> what I'll do.
    >> Lang
    >>> Thoughts, anyone?
    >>> Thanks
    >>> Tim
Reformat, fresh start? problems?
unable to start or reformat my laptop monster528 General Discussion 23 20 Feb 2011
Slow start up after reformat TK21 General Discussion 7 28 Jan 2010
VISTA Ultimate fresh reformat clean Installation failure - hangs... sniper968 Vista installation & setup 8 27 Jul 2009
New year fresh start... Vista 64 bluesmoke General Discussion 4 31 Dec 2008
Fresh start with Complete PC Backup tommyb Vista performance & maintenance 7 07 Nov 2007
