| | Full system backup is so small? I just did a full backup of my Vista RTM to an USB disk. Before starting the backup I cleaned up unnecessary files and 'cleaned' th ehibernation file to reduce size. Drive C then still contained about 60 GB of files (little or no data files: those are stored on another drive, I backed up C: only). Because backup finished surprisingly fast, I took a look at the backup files afterward: there's only 15 GB. How come it's only 1/4 of the contents of my C drive? |
| | Re: Full system backup is so small? compression... if you have any doubts, do a restore to test it all out "Lucvdv" <name@null.net> wrote in message news:t9s7p2dquctmiascvfijdkogf4iq9i3cm4@4ax.com... >I just did a full backup of my Vista RTM to an USB disk. > > Before starting the backup I cleaned up unnecessary files and > 'cleaned' th ehibernation file to reduce size. > > Drive C then still contained about 60 GB of files (little or no data > files: those are stored on another drive, I backed up C: only). > > > Because backup finished surprisingly fast, I took a look at the backup > files afterward: there's only 15 GB. How come it's only 1/4 of the > contents of my C drive? |
| | Re: Full system backup is so small? The once, and only once, that i actually used the Complete PC Backup option in Vista the resulting backup file was not compressed. I had 30GB of data to backup and the backup file was 30GB. Assuming that compression was available (and i haven't found any compression options as of yet) there is no way that 60GB would be compressed down to 15GB - even Acronis True Image can't compress the file that much. 50%, maybe but not down to 25% -- John Barnett MVP Associate Expert Windows Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "Lucvdv" <name@null.net> wrote in message news:t9s7p2dquctmiascvfijdkogf4iq9i3cm4@4ax.com... >I just did a full backup of my Vista RTM to an USB disk. > > Before starting the backup I cleaned up unnecessary files and > 'cleaned' th ehibernation file to reduce size. > > Drive C then still contained about 60 GB of files (little or no data > files: those are stored on another drive, I backed up C: only). > > > Because backup finished surprisingly fast, I took a look at the backup > files afterward: there's only 15 GB. How come it's only 1/4 of the > contents of my C drive? |
| Screen print copied to Paint prints small not full size?? | Vista General | |||
| Software for full system backup /restore | Vista General | |||
| System crash on full backup to WD external drive | Vista hardware & devices | |||
| Full system backup on new partion... please help! | Vista General | |||
| Vista "full system backup" | Vista General | |||
