| | Retail box contains both 32/64bit right? Did I understand correctly in that there are not separate retail packages but that you will have the option to install either 32bit/64bit when you install? |
| | Re: Retail box contains both 32/64bit right? the dvd itself has both versions.. but the product key will be for the one you have bought "Rob" <nospam@nospam.com> wrote in message news:ObTbEPqLHHA.1008@TK2MSFTNGP06.phx.gbl... > Did I understand correctly in that there are not separate retail packages > but that you will have the option to install either 32bit/64bit when you > install? > |
| | Re: Retail box contains both 32/64bit right? One product key 2 DVDs -- 1: x64 2: x86 "Red nosed reindeer" <-> wrote in message news:OYEKGRqLHHA.1008@TK2MSFTNGP06.phx.gbl... | the dvd itself has both versions.. | | but the product key will be for the one you have bought | | | "Rob" <nospam@nospam.com> wrote in message | news:ObTbEPqLHHA.1008@TK2MSFTNGP06.phx.gbl... | > Did I understand correctly in that there are not separate retail packages | > but that you will have the option to install either 32bit/64bit when you | > install? | > | | |
| | Re: Retail box contains both 32/64bit right? oh yes sorry... I was thinking about the various versions of vista (home buisiness etc).. not 32-64 bit my mistake "DCR" <dcr@nyc.rr.com> wrote in message news:eIaFaVqLHHA.4000@TK2MSFTNGP06.phx.gbl... > One product key > 2 DVDs -- 1: x64 2: x86 > > > "Red nosed reindeer" <-> wrote in message > news:OYEKGRqLHHA.1008@TK2MSFTNGP06.phx.gbl... > | the dvd itself has both versions.. > | > | but the product key will be for the one you have bought > | > | > | "Rob" <nospam@nospam.com> wrote in message > | news:ObTbEPqLHHA.1008@TK2MSFTNGP06.phx.gbl... > | > Did I understand correctly in that there are not separate retail > packages > | > but that you will have the option to install either 32bit/64bit when > you > | > install? > | > > | > | > > |
| | Re: Retail box contains both 32/64bit right? At this point it appears that both DVD's will be included with the FULL edition and the 64-bit DVD will have to be ordered with the upgrade. Full Version you will be able to install either one as a custom install. Upgrade will only work for the bit version you have to install from "Rob" <nospam@nospam.com> wrote in message news:ObTbEPqLHHA.1008@TK2MSFTNGP06.phx.gbl... > Did I understand correctly in that there are not separate retail packages > but that you will have the option to install either 32bit/64bit when you > install? > |
| | #6 (permalink) |
| | Re: Retail box contains both 32/64bit right? John Barnes wrote: > At this point it appears that both DVD's will be included with the FULL > edition and the 64-bit DVD will have to be ordered with the upgrade. Full > Version you will be able to install either one as a custom install. > Upgrade will only work for the bit version you have to install from Clarification on that last statement. There will be no way to upgrade XP64 to Vista64. You can use the upgrade version of Vista but you will have to do a clean install. -- Tom Porterfield |
| | #7 (permalink) |
| | Re: Retail box contains both 32/64bit right? Thanks. :-) "Tom Porterfield" <tpporter@mvps.org> wrote in message news:%23C7uu9qLHHA.4460@TK2MSFTNGP03.phx.gbl... > John Barnes wrote: >> At this point it appears that both DVD's will be included with the FULL >> edition and the 64-bit DVD will have to be ordered with the upgrade. >> Full >> Version you will be able to install either one as a custom install. >> Upgrade will only work for the bit version you have to install from > > Clarification on that last statement. There will be no way to upgrade > XP64 to Vista64. You can use the upgrade version of Vista but you will > have to do a clean install. > -- > Tom Porterfield |
| | #8 (permalink) |
| | Re: Retail box contains both 32/64bit right? Actually, I think John meant to say you can upgrade an existing Vista x64 SKU such as Vista Home Premium x64 to Ultimate x64. But as you rightly said, no upgrade paths from XP x64 to Vista x64. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry "Tom Porterfield" <tpporter@mvps.org> wrote in message news:%23C7uu9qLHHA.4460@TK2MSFTNGP03.phx.gbl... > John Barnes wrote: >> At this point it appears that both DVD's will be included with the FULL >> edition and the 64-bit DVD will have to be ordered with the upgrade. >> Full >> Version you will be able to install either one as a custom install. >> Upgrade will only work for the bit version you have to install from > > Clarification on that last statement. There will be no way to upgrade > XP64 to Vista64. You can use the upgrade version of Vista but you will > have to do a clean install. > -- > Tom Porterfield |
| | #9 (permalink) |
| | Re: Retail box contains both 32/64bit right? Oops guess I also misinterpreted. :-) Sorry Tom. -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry "John Barnes" <jbarnes@email.net> wrote in message news:%23nzUzIrLHHA.5000@TK2MSFTNGP03.phx.gbl... > Thanks. :-) > > "Tom Porterfield" <tpporter@mvps.org> wrote in message > news:%23C7uu9qLHHA.4460@TK2MSFTNGP03.phx.gbl... >> John Barnes wrote: >>> At this point it appears that both DVD's will be included with the FULL >>> edition and the 64-bit DVD will have to be ordered with the upgrade. >>> Full >>> Version you will be able to install either one as a custom install. >>> Upgrade will only work for the bit version you have to install from >> >> Clarification on that last statement. There will be no way to upgrade >> XP64 to Vista64. You can use the upgrade version of Vista but you will >> have to do a clean install. >> -- >> Tom Porterfield > |
| | #10 (permalink) |
| | Re: Retail box contains both 32/64bit right? Andre Da Costa[ActiveWin] wrote: > Oops guess I also misinterpreted. :-) Sorry Tom. Well, that's just my interpretation of the note at http://www.microsoft.com/windowsvist...gradeinfo.mspx which says: "If you are currently using Windows 2000 Professional or Windows XP Professional x64, you are eligible for an upgrade copy to a corresponding or better edition of Windows Vista, but a clean install is required." -- Tom Porterfield |
| OEM 64Bit DVD Installed with Retail CD Key?? | Vista installation & setup | |||
| Order 64bit Installation Media - Not working for *Retail* license | Vista installation & setup | |||
| Vista Home Premium Retail - 64bit pending - Serial Key question | Vista installation & setup | |||
| Vista Ultimate Retail Box 64bit edition | Vista General | |||
| Retail 32bit XP -> Retail Upgrade to 64bit Vista. (Clarify) | Vista General | |||
