Vista - restore points and previous versions (vss)
Old 01-04-2007   #1 (permalink)
Troy McClure
ok weird one here... vista business rtm. all was well... if i right clicked a fole or folder that had been modified since the last restore point was taken i could go to previous versions and see a list of all previous versions of the file and restore one. suddenly the entire previous versions tab is blank and the buttona are greyed out. see attached image....
whats going on here? system restore IS running... i created manual restore points to test things... restore points are successful, yet this still doesnt work.
Old 01-04-2007   #2 (permalink)
Dennis Pack
Re: restore points and previous versions (vss)
Troy:
If you're dual booting XP and Vista, when you boot into XP it will erase all VSS files in Vista.
Dennis Pack
Vista x64 Enterprise
Office 2007
"Troy McClure" <nun@4u.com> wrote in message news:OdKwclDMHHA.1044@TK2MSFTNGP02.phx.gbl...
Old 01-04-2007   #3 (permalink)
Troy McClure
not dual booting.
and again, this all worked fine up until today.
this is making me nuts... anyone?
"Dennis Pack" <dennispack@nospam.hotmail.com> wrote in message news:2DD4CF0C-8F05-4263-BED3-DFC5696C37D4@microsoft.com...
Troy:
Dennis Pack
Office 2007
Old 01-04-2007   #4 (permalink)
michail iakovou yos
I am still waiting for someone to give a solution to this,
without buying that software that is a bootloader (NG I think its called?)
I would much appreciate some way to get around this..
if anyone has any idea, please tell me, since hiding the partitions with acronis did not work.
Troy:
Dennis Pack
Office 2007
Old 01-04-2007   #5 (permalink)
Richard Urban
How do you defrag? This question "may" be relevant.
Regards,
Richard Urban
Quote from George Ankner:
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
"Troy McClure" <nun@4u.com> wrote in message news:uEES1wDMHHA.5016@TK2MSFTNGP04.phx.gbl...
not dual booting.
Troy:
Dennis Pack
Office 2007
Old 01-04-2007   #6 (permalink)
Troy McClure
i havent ever on this system....
any other thoughts?
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message news:%23bDhe5DMHHA.1008@TK2MSFTNGP06.phx.gbl...
Regards,
Richard Urban
not dual booting.
Troy:
Dennis Pack
Office 2007
Old 01-04-2007   #7 (permalink)
Jill Zoeller [MSFT]
I'm asking about this now. It looks like the page isn't rendering correctly. If there were no previous versions, you'd still see the box iwth the Name, Date modified, and Location columns, along with the text "There are no previous versions available."
Want to learn more about Windows Server file and storage technologies? Visit our team blog at http://blogs.technet.com/filecab/default.aspx.
Old 01-04-2007   #8 (permalink)
Richard Urban
Unfortunately, as others have told you, I see no way around this other than using a 3rd party boot loader. I use System Commander and suffer no such problems in booting between Windows XP, Vista and DOS.
Regards,
Richard Urban
"michail iakovou yos" <1@1.1> wrote in message news:O4fWB3DMHHA.960@TK2MSFTNGP04.phx.gbl...
Troy:
Dennis Pack
Office 2007
Old 01-04-2007   #9 (permalink)
MICHAEL
Why does everyone keep sending that screenshot with
their replies?
Regards,
Richard Urban
not dual booting.
Troy:
in Vista.
Dennis Pack
Office 2007
Old 01-04-2007   #10 (permalink)
Tom Porterfield
If you don't want to pay for a boot manager, there are free ones available.
I can't personally recommend a free one as I haven't used one of them. But
the problem is if XP sees or enumerates the partition it's going to stomp on
the volume snapshots created by Vista because it doesn't understand them.
So your only option is to make the Vista partition completely invisible to
XP. Doing this before the boot process is even turned over to XP is the
safest way as that guarantees XP won't see the partition. You also need a
solution that allows you to unhide the Vista partition when you want to boot
into Vista. So a boot manager that supports hiding other partitions that
contain the Vista installation when booting into XP and then unhides it when
you choose to boot into Vista is an effective way to get around the problem.
The other solution would be for MS to supply an update to XP that fixes the
problem. For that you'll have to wait, with no commitment from MS that they
are ever going to provide such an update for XP.
Tom Porterfield
Restore Previous Versions - Restore or Remove from Context Menu Tutorials
Previous Versions Tab - Restore or Remove from Properties Tutorials
Restore Previous Versions menu item missing/hidden? Vista General
No previous versions to restore Vista performance & maintenance
Help on Restore Previous Versions Vista General
