| Guest | urgent re startup problem I just installed bluesoleil software for my bluetooth and found it does not work with vista. The problem is when it starts up I get a blue screen stop error. Thing is after restarting from the blue screen, the program loads again as it is in the startup and I do not get a chance to remove it from startup before it blue screens again. Is there any way to access the startup files for Vista from within XP partition so I can remove it? Currently I am just stuck in a loop. |
| Guest | Re: urgent re startup problem Boot from the DVD. Choose repair system. There you will find that you can restore your system to an earlier point in time.. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "Beck" <beck@none> wrote in message news:ucD2TqbMHHA.4916@TK2MSFTNGP06.phx.gbl... >I just installed bluesoleil software for my bluetooth and found it does not >work with vista. The problem is when it starts up I get a blue screen stop >error. > Thing is after restarting from the blue screen, the program loads again as > it is in the startup and I do not get a chance to remove it from startup > before it blue screens again. > > Is there any way to access the startup files for Vista from within XP > partition so I can remove it? Currently I am just stuck in a loop. > |
| Guest | Re: urgent re startup problem "Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message news:eVgN7wbMHHA.4376@TK2MSFTNGP03.phx.gbl... > Boot from the DVD. Choose repair system. There you will find that you can > restore your system to an earlier point in time.. Thanks. I did actually fix it by booting into vista safe mode and using msconfig from there. Then rebooted into normal mode and uninstalled the offender. Shame I did not thank about it prior to posting. |
| Urgent problem please help. | General Discussion | |||
| Urgent Problem! | Vista account administration | |||
| startup failure. rather urgent. | Vista hardware & devices | |||
| startup repair tool missing urgent! | Vista installation & setup | |||
| Urgent - TCP/IP problem | Vista General | |||
