1.    07 Jan 2007 #1
    Radioman Guest
    Problems writing Vista DVD iso to DVD...
    Hi all,
    This sounds like a really silly question.
    But I am having (apparently) severe problems writing the Vista downloaded
    ..iso to DVD.
    I know it is a disk image (I have done the write countless times with .iso
    for Linux etc) and when I try to write with Nero, I get read errors in the
    last segments of the disc.
    I have downloaded Vista twice, but continue to get verification errors...
    Has anyone else had these problems?
    I do not want to trust a 'bad disc' for a Vista install.
    Any yes:
    a) I have tried 4 different makes of DVD
    b) I have tried 2 recorders (which previously wrote fine)
    c) I have written at the slowest possible speed
    d) I have tried another writing program as well as Nero.
    QUESTION - will an extracted ISO which is obviously many seperate files, be
    expected to verify after writing or am I assuming there is a problem when
    there is none? The ISO is of course one file, the written extrected disc
    contains many files.
    Please advise!!
  2.    07 Jan 2007 #2
    Richard Urban Guest
    Re: Problems writing Vista DVD iso to DVD...
    Where did you get the download from????? (-;
    If you obtained it from Microsoft, you could have copied the SHA hash number
    and then compared the downloaded file against this hash. If the file checks
    OK, then you got a good download. If it doesn't - you need to download it
    again.
    Now, if you didn't get it from Microsoft - well, you will just have to
    figure it out on your own!
    Regards,
    Richard Urban
    Quote from George Ankner:
    If you knew as much as you think you know,
    You would realize that you don't know what you thought you knew!
    "Radioman" <Radioman@discussions.microsoft.com> wrote in message
    news:1637DE7E-B21C-4A8D-B710-B88B19969E38@microsoft.com...
    > Hi all,
    > .iso to DVD.
    > Any yes:
    > be
    > Please advise!!
  3.    07 Jan 2007 #3
    Radioman Guest
    I got it FULLY OFFICIALLY from Microsoft.
    I have checked the SHA1 hash and it was fine each time I downloaded it.
    The comparison was correct.
    So I am therefore totally puzzled about the so called 'verification errors'
    from Nero and another program.
    > again.
    > Regards,
    > Richard Urban
    > > Hi all,
    > > .iso to DVD.
    > > Any yes:
    > > be
    > > Please advise!!
  4.    07 Jan 2007 #4
    Richard Urban Guest
    I have never used Nero to burn the DVD. But I have used Roxio Easy Media
    Creator to bun the DVD's about 12-15 times. I have never had a problem using
    Roxio.
    Are you burning within Windows XP? You should.
    Regards,
    Richard Urban
    news:4414E0DE-6DF1-49A4-959F-49980AA6017D@microsoft.com...
    > errors'
    >> number
    >> checks
    >> again.
    >> Regards,
    >> Richard Urban
    >> > Hi all,
    >> > downloaded
    >> > .iso to DVD.
    >> > .iso
    >> > the
    >> > errors...
    >> > Any yes:
    >> > files,
    >> > be
    >> > when
    >> > disc
    >> > Please advise!!
  5.    07 Jan 2007 #5
    Brian Lew Guest
    You can use ISO Recorder, a free power toy for Windows XP. Here's the
    website http://isorecorder.alexfeinman.com/isorecorder.htm
    and the download link
    http://isorecorder.alexfeinman.com/d...orderV2RC1.msi
    > Roxio.
    > Regards,
    > Richard Urban
    > > errors'
    > >> number
    > >> checks
    > >> again.
    > >> Regards,
    > >> Richard Urban
    > >> > Hi all,
    > >> > downloaded
    > >> > .iso to DVD.
    > >> > .iso
    > >> > the
    > >> > errors...
    > >> > Any yes:
    > >> > files,
    > >> > be
    > >> > when
    > >> > disc
    > >> > Please advise!!
  6.    07 Jan 2007 #6
    Radioman Guest
    Ok I copied the DVD file to another computer with a Sony recorder..
    The others were Panasonic on XP x64 - but they have never had a problem like
    this..
    But on the other computer running 32 bit windows, it wrote and verified ok..
    Using of all things Ashampoo Burning Studio 5.
    It is now installing. There was (with the versions with errors on the disc)
    an installation error detected during unpacting of files - but this time it
    has run through and has nearly completed the install.
    So it obviously was a disc write error (I tried a couple of programs to
    verify the SHA1 and both gave the same, correct value). But it's really odd..
    Maybe a bug in x64 but I can't believe that.
    Will report if Vista installed ok, and thanks for the advice.
    Cheers all.
    > > Roxio.
    > > Regards,
    > > Richard Urban
    > > > errors'
    > > >> number
    > > >> checks
    > > >> again.
    > > >> Regards,
    > > >> Richard Urban
    > > >> > Hi all,
    > > >> > downloaded
    > > >> > .iso to DVD.
    > > >> > .iso
    > > >> > the
    > > >> > errors...
    > > >> > Any yes:
    > > >> > files,
    > > >> > be
    > > >> > when
    > > >> > disc
    > > >> > Please advise!!
  7.    07 Jan 2007 #7
    Radioman Guest
    HELP ISO recorder..
    I have installed ISO recorder but where the devil IS it??
    Cheers.
    > this..
    > Cheers all.
    > > > Roxio.
    > > > Regards,
    > > > Richard Urban
    > > > > errors'
    > > > >> number
    > > > >> checks
    > > > >> again.
    > > > >> Regards,
    > > > >> Richard Urban
    > > > >> > Hi all,
    > > > >> > downloaded
    > > > >> > .iso to DVD.
    > > > >> > .iso
    > > > >> > the
    > > > >> > errors...
    > > > >> > Any yes:
    > > > >> > files,
    > > > >> > be
    > > > >> > when
    > > > >> > disc
    > > > >> > Please advise!!
  8.    07 Jan 2007 #8
    Frank Saunders, MS-MVP OE/WM Guest
    Re: HELP ISO recorder..
    news:77F28486-285D-47A8-8ABE-949BDD5F4B7B@microsoft.com...
    > Hi,
    Right click on the ISO you want to burn.
    http://www.fjsmjs.com
    Answer in newsgroup. Don't send mail.
  9.    07 Jan 2007 #9
    Radioman Guest
    Ok thanks - that works..
    And Vista installed correctly!
    Cheer all.
    > > Hi,
  10.    07 Jan 2007 #10
    Nancy Ward Guest
    > errors'
    >> number
    >> checks
    >> again.
    >> Regards,
    >> Richard Urban
    >> > Hi all,
    >> > downloaded
    >> > .iso to DVD.
    >> > .iso
    >> > the
    >> > errors...
    >> > Any yes:
    >> > files,
    >> > be
    >> > when
    >> > disc
    >> > Please advise!!
    Radioman, go out and get imgburn and burn your iso from there. It's simple,
    and easy to use, and gives a good iso copy every time. www.imgburn.com
    Nancy Ward
    Windows Live Butterfly
    Windows Live Messenger MVP 2003-2006
Page 1 of 2 12 LastLast
Writing this from my brother's XP, my vista is in PERIL!
Here's the deal. I start up my Lenovo Vista as usual, and then I start normal mode. The microsoft loading thing comes up, and the Vista symbols...
Vista General
Vista not reading/Writing CD/DVD
Hello there, I'm currently having a problem here, My Vista Business desktop seems to have stopped reading cd's and dvd's and also not writing...
General Discussion
Problems seeing the page when writing email, will not scroll down
Starting today, when writing an email message, when my typing gets to the bottom of the viewable page, I can no longer see what I am typing. What...
Vista mail
Vista problems, especially writing dvds - UK posting
I bought an Advent 9115 laptop last week, with 2g of Ram, a 1.4 ghz dual core processor, running Vista. This seems to be PC world's 'own brand',...
Vista General
Vista Writing to disk
Just a question to ask if anyone knows why explorer.exe and rundll.exe would be writing almost 600kb a second to the harddrive of my laptop to files...
Vista performance & maintenance
VERY slow writing to DVD drive in Vista
I have a new computer (dual core 2.13GHz) computer with a dual boot to Vista Home Premium and WinXP sp2. When I try to copy/write files to my...
Vista hardware & devices
Over writing vista files
I have an activated and registered copy of Windows Vista Home Premium installed. Since using an anti spyware and registry checker program (which I...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
