| | Problem with USB External Hard Disk Hi, I'm having problem writing to my USB External Hard Disk. Every time I copy files to it, they got corrupted (if I reopen them later). There is no error during copy (which mean, the copying process is successful). To make a simple test, just compress some files (around 10mb and above) and copy the compress file to the external hard disk. Then open it from the external hard disk and test the archive. I used WinAce and WinRAR. I tried changing the hard disk (but still using the same USB External Hard Disk case) and the result is the same. There is no such problem with USB Flash Disk (plugged into the same USB Port). I tried my USB External Hard Disk on my other computers (WinXP), and everything got written without any problem. Is there anyone out there with the same problem? Thanks. |
| | Re: Problem with USB External Hard Disk Ever since I updated my video card to one with 512MB memory, getting external USB hard drives to work reliably has been a royal pain. This is on Vista Ultimate x64 RTM. I'm afraid all I can add to your message is "me, too!" While I have it working at the moment, I'm not at all sure why and I doubt it will last. :-} "Poh Tze Siang" <n0sp4m_programatix@msn.com> wrote in message news:59F965AE-98A0-4DC3-A59B-627258EC7A71@microsoft.com... > Hi, > > I'm having problem writing to my USB External Hard Disk. Every time I copy > files to it, they got corrupted (if I reopen them later). There is no > error during copy (which mean, the copying process is successful). To make > a simple test, just compress some files (around 10mb and above) and copy > the compress file to the external hard disk. Then open it from the > external hard disk and test the archive. I used WinAce and WinRAR. > > I tried changing the hard disk (but still using the same USB External Hard > Disk case) and the result is the same. There is no such problem with USB > Flash Disk (plugged into the same USB Port). > > I tried my USB External Hard Disk on my other computers (WinXP), and > everything got written without any problem. > > Is there anyone out there with the same problem? > > Thanks. |
| Windows - No Disk error after installing an external hard disk | Vista hardware & devices | |||
| Vista - USB External Hard Disk | Vista General | |||
| External hard disk | Vista hardware & devices | |||
| Unreadable External hard disk | Vista General | |||
