Vista - Sound Recorder
Old 01-22-2007   #1 (permalink)
Synapse Syndrome
Sound Recorder
How do you select what input is recorded with the Sound Recorder? There
doesn't seem to be a Record sound mixer, like in XP.
ss.
Old 01-23-2007   #2 (permalink)
Keith Miller MVP
Re: Sound Recorder
Control Panel -> Sound -> 'Recording' tab -> select the source you want &
click 'Set Default'
Good Luck,
Keith
Microsoft MVP [Windows XP Shell/User]
"Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message
news:u0v0lgoPHHA.992@TK2MSFTNGP06.phx.gbl...
> ss.
Old 01-23-2007   #3 (permalink)
John Blessing
Re: Sound Recorder
> ss.
While on the topic of Sound Recorder... Why on earth did MS rename
sndrec32.exe to soundrecorder.exe????
Do they never consider that they might be breaking legacy code ? -
obviously not.
John Blessing
http://www.LbeHelpdesk.com - Help Desk software priced to suit all
businesses
http://www.room-booking-software.com - Schedule rooms & equipment bookings
for your meeting/class over the web.
http://www.lbetoolbox.com - Remove Duplicates from MS Outlook, find/replace,
send newsletters
Sound Recorder Vista General
?????? Sound Recorder ???????????? Vista General
How to record sound clips or music using the sound recorder? Vista music pictures video
sound recorder Vista music pictures video
