Vista - Vista - Internet speed very slow - Help out of ideas
Old 01-24-2007   #11 (permalink)
Mike
Re: Vista - Internet speed very slow - Help out of ideas
"Rich C" <RichC@discussions.microsoft.com> wrote in message
news:9AAC537C-3C55-4C83-AD2D-7BD3B51D41C0@microsoft.com...
> ok lets try again
> in xp - i get 300 kbs downloads on the net
> in vista i get 30kbs MAX.
> i have tried netsh int tcp set global autotuninglevel=disabled
> but that didnt help.. am all out of ideas and its the only thing that is
> stopping me loving this awsome os
Rich..
1. Can you try direct connect and bypass the router to see what happens
then?
2. Others have reported some problems and a router firmware update seems to
have fixed that.
3. Which model router?
Old 01-24-2007   #12 (permalink)
Rich C
thanks mike for a nice reply !
its an ancient DLINK 604+ i am going to check this out by swapping it over
with a mates if he will let me
HOWEVER - I use checkpoint secureremote - and I have a feeling this all
started when I installed secure remote....so I am going to speak to
checkpoint and see if it is something they have had replies about before.....
cheers
ps sorry if i was angry - i really needed help not snipey comments and ppl
knew what i meant
> > ok lets try again
> Rich..
> then?
> have fixed that.
Old 01-24-2007   #13 (permalink)
Rich C
also try this:
http://blogs.technet.com/markrussino...27/532465.aspx
> cheers
> knew what i meant
> > > ok lets try again
> > Rich..
> > then?
> > have fixed that.
Old 01-24-2007   #14 (permalink)
Robert Moir
> over with a mates if he will let me
I'd make sure the duplex settings on this router match those on the network
card... Obvious point you've probably looked at already but deserves to be
checked. I'd also see if your network card has driver updates available
(sorry can't remember if you said you already checked this).
> all started when I installed secure remote....so I am going to speak
> to checkpoint and see if it is something they have had replies about
> before.....
Vista has had a lot of issues with VPN clients that are not designed for
Vista because the network stack has had a major re-write and that, of course
is what VPN clients need to dig into. Does the checkpoint product claim
Vista compatability?
> and ppl knew what i meant
Don't want to keep on about this bit, but the question wasn't whether _we_
understood what you were writing or not, but whether or not _you_ understood
what you were writing and were therefore writing something accurate rather
than just repeating what "someone told you once", which we get here a lot.
If you went to a mechanic for a problem with your car and described the
noise it was making, would you expect them to clarify exactly what was
happening before or after your engine was in pieces all over the floor?
regards
Rob.
Old 01-24-2007   #15 (permalink)
Rich C
hi
the checkpoint VPN claims vista ok - there eval kits so there not final..
its possible that its destroyed my networking - I tried to uninstall it and
it was still slow after the uninstall..
so it looks like I have a dead copy of vista that will require a clean
install... never mind... Like the grolsh - its not ready
> > before.....
> regards
> Rob.
Old 01-24-2007   #16 (permalink)
Gary
Also try and disable IPV6 in the IP settings. Sometimes this helps.
news:48DDA805-7188-4245-94BF-30FB2FF8FD65@microsoft.com...
> hi
> and
>> network
>> be
>> > before.....
>> course
>> _we_
>> understood
>> rather
>> lot.
>> regards
>> Rob.
Old 01-24-2007   #17 (permalink)
thetruthhurts @homail.com
You retards remind of the tech support "guru" on SNL. Mega bits or
bytes, gimme a break.
This is not rocket science, his internet speed is much slower under
Vista as opposed to XP. I too have experienced the same problem,
though not nearly to the same degree. I was hoping to find some
valuable info in this thread, as opposed to a bunch a nerds pining and
splitting hairs.
This is not your personal play ground, if you don't have some of value
to add STFU.
On Wed, 24 Jan 2007 16:42:42 -0500, "AJR" <ajrjdr@comcast.net> wrote:
>Rich - you are "messed up" and should apologize to the previous responders.
>Broadband dial-up and network "speeds" are NOT expressed in terms of
>"megabytes " but in terms if "megabits per second". To determine the speed
>in bytes you divide the "bits by eight".
> With your attitude - good luck in getting assistance!
>news:A1AFA872-75E6-4634-93D0-E07CC8D6143F@microsoft.com...
>> how is telling me that I am typing the speed of my broadband going to
>> help?
>> its a 8MBS connection with pipex.....
>> in no way have either of ur previous comments helped
>> vista has a serious problem - i need help not people that provide me with
>> stress and anger
>> "Peter Foldes" wrote:
>>> Rich
>>> That is a bad attitude to take against someone that is trying to help
>>> Peter
>>> Please Reply to Newsgroup for the benefit of others
>>> Requests for assistance by email can not and will not be acknowledged.
>>> news:5EFF4A3F-79F5-41D6-9CBA-E194E705B59A@microsoft.com...
>>> > obvioulsy 8mbs - if u cant help please dont reply
>>> > "Troy McClure" wrote:
>>> >> but more importantly, where are you and what service do you have that
>>> >> gives
>>> >> 8MB connections?
>>> >> we're talking megaBYTES, and not megaBITS, right?
>>> >> "Rich C" <Rich C@discussions.microsoft.com> wrote in message
>>> >> news:7BEB1074-F76C-4ECE-BC54-08BC05DC25E5@microsoft.com...
>>> >> > hi
>>> >> > I am getting such slow internet speeds on 8mbs connection xp was
>>> >> > fine.
>>> >> > Vista only gives me 1mbs of bandwidth - something is wrong - any
>>> >> > ideas?
>>> >> > its a decent spec pc and this is such a let down of vista
>>> >> > DLINK Router connected via cable
>>> >> > have tried:
>>> >> > 1 - disabling all the windows protection crap
>>> >> > 2 - setting autolevel to disable
>>> >> > 3 - different network cards
>>> >> > I am all out of ideas - please help
Old 01-24-2007   #18 (permalink)
Chad Harris
Rich none of this will hurt you, and it might help. I realize your problem
is primarily involving downloads speed on your internet connection. All
those citizens of tomorrow in prime time who are downloading their movie and
mu sic collection by stealing it aren't helping download speeds either. I
read the rest of the thread:
Do these things and see if this helps:
Speed PC and Control CPU Tips/Steps
SPEED AND CPU:
_______________
1) Trim processes you don't need in TM. Google them or "search engine of
your choice them" if you have to.
2) Go to
services.msc in run box and turn off services not needed and there are some.
Vista Services Guide Part 1
http://www.tweakvista.com/article38662.aspx
Vista Services Guide Part 2
http://www.tweakvista.com/article38664.aspx
3) Run System File Checker.
SFC: http://www.updatexp.com/scannow-sfc.html
In Vista run it from an elevated command prompt. Right click command on
start and run as administrator.
4) Run 3 or so spyware scans Windows Defender, , Adaware, and Spybot
5) Probably the most important for speed consistently and efficient resource
use DEFRAG with www.raxco.com or www.diskeeeper.com with 15% free space on
drive if DK and or >5% if Raxco's Perfect Disk.
http://groups.msn.com/windowsxpcentral/spyware.msnw Download Adaware and
Spybot from here.
GOOD Overall Review for Defending Your PC:
http://defendingyourmachine.blogspot.com/
MSFT Defense Site MSFT Security:
http://www.microsoft.com/security/default.mspx
Protect Your PC from MSFT Security:
http://www.microsoft.com/athome/secu...t/default.mspx
MSFT Windows Defender
http://www.microsoft.com/athome/secu...e/default.mspx
MSFT MSRT: (Malicious Software Removal Tool)
http://www.microsoft.com/security/ma...e/default.mspx
MSFT "Windows One Care" in Wings (AV and Spyware Scans)
http://www.microsoft.com/presspass/p...OneCarePR.mspx
6) Unck items from msconfig start tab you don't need starting and some
won't start--peoiple who think just uncking for many are naive because there
are 12 places things can be started including several reg keys like Run Once
keys and there are serveral.
7) Turn off Messaging service--it's a security vulnerability and it slows
you
8) Defrag very often every other day actually.
9) Turn off indexing.
10) Clear TIF and %temp% files (delete) and go to safe mode to get as many
as u can.
10) Do troubleshooting with msconfig.
11) Do Clean boot with msconfig utility and search for the directions here:
SERVICE CONFIGURATION REFERENCES*
*Vista Services*
Part One
Part Two
Windows Vista Services Tweak Guide v1.0
http://www.msfn.org/board/index.php?showtopic=87443
Vista RTM Tweak Guide (Tweaks to Improve Performances)
http://www.google.com/search?sourcei...tm+tweak+guide
1) Task Manager lists the services on the services tab in Vista.
2) Type services.msc in run box and using the list of services, click the
service and you'll get a description of services.
3) There is a list here of the default services and a description>>click
"default settings for services" in the left pane.
http://technet2.microsoft.com/Window....mspx?mfr=true
4) To view service dependencies
1.
Open Services.
2.
In the details pane, right-click the service that you want to view
dependencies for, and then click Properties.
3.
Click the Dependencies tab.
4.
To view services that are associated dependencies of the selected service,
in the list on the Dependencies tab, click the plus sign next to the
service.
Many of the services but not all in Vista are the same as in XP, so in that
context:
http://www.mvps.org/winhelp2002/services.htm
Also see the extremely helpful site:
Black Viper's Service List
http://www.dead-eye.net/WinXP%20Services.htm
Black Viper's Site (Many of the same services in Vista)
http://www.z123.org/techsupport/xpservices.htm
http://www.geocities.com/ziyadhosein/xpserv1.htm
http://www.pacs-portal.co.uk/startup_content.php
This will be helpful
http://web.archive.org/web/200411280...servicecfg.htm
______________________________________________________________________________________________
How to troubleshoot by using the System Configuration utility in Windows XP
http://support.microsoft.com/kb/310560/
Resources for troubleshooting startup problems in Windows XP
http://support.microsoft.com/kb/308041/
How to perform advanced clean-boot troubleshooting in Windows XP
http://support.microsoft.com/default...b;en-us;316434
How to perform a clean boot in Windows XP
http://support.microsoft.com/kb/310353/
How to Disable a Service or Device that Prevents Windows from Starting
http://support.microsoft.com/kb/310602/
Also ck out these references:
http://www.extremetech.com/article2/0,1558,5155,00.asp
http://www.speedupyourcomputer.windo....com/index.htm and
http://www.extremetech.com/search_re...app=&site=4P.S.
Defragging with a decent defrag every day will make a huge dent inefficient
resource/CPU use.Good luck,CH
Perfect Disk has a 5 month full functionality trial on now for Windows
Vista.
Good luck,
CH
> hi
> and
>> network
>> be
>> > before.....
>> course
>> _we_
>> understood
>> rather
>> lot.
>> regards
>> Rob.
Old 01-24-2007   #19 (permalink)
Chad Harris
I think some SNL segments are very good lately, but nothing will equal the
classic aero with the original gang.
I'd like to say that every one of the last few builds of Vista I've found
every aspect of Vista's IE7 and internet connectivity and downloads to be
faster than XP which is running fast on a dual boot on the same box.
I also would like to apply to qualify as the quintissential retard.
CH
I'd like to give a big shout out to the country's newest unindicted
co-conspirator Dick Cheney. I'd also like to congratulate Cheney for doing
more aerobics last night while his puppet moron spoke than he has in the
last 45 years.
Big shout out to Condi Rice who the Washington Post took apart today because
lol the Sec of State and former Associate Dean of Stanford University
didin't know her ass from a hole in the ground as to middle east geography.
Is their any chance that Latoya Jackson and the stars of CBS' "Armed and
Famous" could be turned lose on the Mahdi Army? Latoya Johnson as a hooker
decoy is the essence of the American cultural milieu What could be better
than Latoya entertaining the Johns? Les Monves is a cultural icon.
<thetruthhurts @homail.com> wrote in message
news:3hqfr2hi3vtg3rbtuoip2sr59oi4u6glpf@4ax.com...
> splitting hairs.
> to add STFU.
>>responders.
>>> help?
>>> with
>>> stress and anger
>>>> Rich
>>>> Peter
>>>> >> that
>>>> >> gives
>>>> >> 8MB connections?
>>>> >> > hi
>>>> >> > fine.
>>>> >> > ideas?
>>>> >> > have tried:
Old 01-24-2007   #20 (permalink)
Synapse Syndrome
"Troy McClure" <g@s.com> wrote in message
news:4D5C65CB-EA56-4EFD-B269-DC070462F58A@microsoft.com...
>i was being very serious. thought maybe you were someone that didnt
>understand how it works so maybe you were confused.
LOL! you idiot.
> so you have an 8mbit connection? thats pretty much dialup speed to begin
> with... what were you hitting with xp?
Pretty much dialup speed? LMAO!!
I am still waiting for your screenshot to show me how you aren't a blatant
liar, and to show how you 'can afford' to make mismatched hardware
purchases, whereas I cannot...
ss.
Slow internet speed with Vista Vista networking & sharing
Slow Internet Speed Network & Sharing
RE: Internet +Vista 32-bit: Ideas Anyone Vista networking & sharing
Re: Internet +Vista 32-bit: Ideas Anyone Vista networking & sharing
SLOW UPLOAD SPEED IN VISTA? Vista General
