Unknow NT operating system code 6 detected
  1.    09 Jun 2006 #1
    martin gee Guest
    I keep getting a error window with cmdiag in the windows name and the
    following error: "Unknow NT operating system code 6 detected" and when I
    press OK, it says "Read config file failed!"
    What's wrong?
  2.    09 Jun 2006 #2
    Zack Whittaker Guest
    Re: Unknow NT operating system code 6 detected
    Try another form of install:
    http://www.vistabase.co.uk/welcome.php?getstarted - option 4
    Zack Whittaker
    ZackNET Enterprises: www.zacknet.co.uk
    MSBlog on ResDev: www.msblog.org
    Vista Knowledge Base: www.vistabase.co.uk
    This mailing is provided "as is" with no warranties, and confers no
    rights. All opinions expressed are those of myself unless stated so, and not
    of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
    that up!
    --: Original message follows :--
    "martin gee" <killerost@hotmail.com> wrote in message
    news:C65AADD6-2A3E-4151-B94C-9789E82D5E69@microsoft.com...
    > What's wrong?
  3.    18 Jun 2006 #3
    AndKvs Guest
    I have the same (anoying) problem. I've read the article after the install,
    but I'm pretty sure I've did exactly what it tells me to do.
    Any workaround or something else?
    thanks
    > Zack Whittaker
    > » ZackNET Enterprises: www.zacknet.co.uk
    > » MSBlog on ResDev: www.msblog.org
    > » Vista Knowledge Base: www.vistabase.co.uk
    > » This mailing is provided "as is" with no warranties, and confers no
    > that up!
    > > What's wrong?
  4.    18 Jun 2006 #4
    killerost Guest
    I found out what was wrong with my installation. My omnikey smartcard readers
    XP drivers had installed a .cpl file that vista really didn't like. When I
    deleted the .cpl file everything was OK.
    "AndKvs" wrote:
    > Hi,
    > thanks
    > > Zack Whittaker
    > > that up!
    > > > What's wrong?
If I change my operating system to linux, can I still use windows' system restore?
If I change my operating system to linux and delete my old operating system entirely, will I be able to still use system restore to change my old...
General Discussion
Dell inspiron no drive detected,error code 0141
It has Vista ultimate on it. We have tryed "reseating" the drive a couple of times and the tests still say no hard drive detected. error code...
General Discussion
Re: Anyone run into this error message - setup detected that the operating system in use is not windows vista (32-bit)
Hi Ashton! I have the totally same problem as you. I have also Windows Vista 32-bit. Please could you post *link*, where can I download SP1...
Vista General
COM+ Event System detected a bad return code
Hi, for the last three weeks I've had problems with the COM+ Event System service not starting up. The problem originally showed up when system...
Vista General
I keep getting a error window with cmdiag in the windows name and the following error: Unknow NT operating system code 6 detected and when I press...
Vista General
Unknown nt operating system code 6 detected.
Every time I open Control Panel or type anything into the search box on the Start menu (and a few other random places), I get the following two...
Vista General
I keep getting a error window with cmdiag in the windows name and the following error: Unknow NT operating system code 6 detected What's wrong?
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
