| | Remote Control for Vista Premium Home Edition I have the WinXP Media Center Infrared Remote Control (OEM) that I have used successfully with Windows MCE 2005. I am now running Vista Premium Home Edition and would like to use the same remote with it. When I plug in the USB IR Receiver, Vista recognizes it and it shows up in my device properties. However, the red light on the receiver never turns on as it did on my MCE 2005 machine. With this, the remote does not work. Any ideas on how to get the WinXP Media Center Infrared Remote Control to work with Vista? |
| | RE: Remote Control for Vista Premium Home Edition Media Center 2005 Infrared Remote Control and receiver (OEM) will work on Vista out of the box. Try another USB port ( but do think its at) or pull the batteries out 1/2 hour( at sould clear the remote) or try new batteries. -- Richard A Miller MCE mvp http://www.microsoft.com/mvp "Amar" wrote: > I have the WinXP Media Center Infrared Remote Control (OEM) that I have used > successfully with Windows MCE 2005. I am now running Vista Premium Home > Edition and would like to use the same remote with it. When I plug in the USB > IR Receiver, Vista recognizes it and it shows up in my device properties. > However, the red light on the receiver never turns on as it did on my MCE > 2005 machine. With this, the remote does not work. > > Any ideas on how to get the WinXP Media Center Infrared Remote Control to > work with Vista? |
| | Re: Remote Control for Vista Premium Home Edition My XP MCE ir remote does work properly with Vista Ultimate. Not sure why yours does not, but have you gone through the remote setup routine in Vista MC and does your TV tuner work correctly? "Amar" <Amar@discussions.microsoft.com> wrote in message news:9948DA7C-E76D-4673-8273-C3103336EA8C@microsoft.com... |I have the WinXP Media Center Infrared Remote Control (OEM) that I have used | successfully with Windows MCE 2005. I am now running Vista Premium Home | Edition and would like to use the same remote with it. When I plug in the USB | IR Receiver, Vista recognizes it and it shows up in my device properties. | However, the red light on the receiver never turns on as it did on my MCE | 2005 machine. With this, the remote does not work. | | Any ideas on how to get the WinXP Media Center Infrared Remote Control to | work with Vista? |
| | Re: Remote Control for Vista Premium Home Edition I'm using the Hauppauge WinTV-PVR-150MCE l.p. tv tuner which works great with Vista. The funny thing is the remote worked when I was running Vista RC1 on the same machine. After doing a clean install with the Vista OS I obtained through my MSDN account, the USB IR Receiver stopped working (no red light). I just assumed Microsoft dropped support for this remote in Vista as the new remotes coming out have SideShow functionality. "dirty old man" wrote: > My XP MCE ir remote does work properly with Vista Ultimate. > Not sure why yours does not, but have you gone through the remote > setup routine in Vista MC and does your TV tuner work correctly? > > > "Amar" <Amar@discussions.microsoft.com> wrote in message > news:9948DA7C-E76D-4673-8273-C3103336EA8C@microsoft.com... > |I have the WinXP Media Center Infrared Remote Control (OEM) that I have used > | successfully with Windows MCE 2005. I am now running Vista Premium Home > | Edition and would like to use the same remote with it. When I plug in the USB > | IR Receiver, Vista recognizes it and it shows up in my device properties. > | However, the red light on the receiver never turns on as it did on my MCE > | 2005 machine. With this, the remote does not work. > | > | Any ideas on how to get the WinXP Media Center Infrared Remote Control to > | work with Vista? > > > |
| | RE: Remote Control for Vista Premium Home Edition Thanks for the quick reply! I tried these option actually but with no success. I'm at work now but I'll try again tonight. "Richard Miller" wrote: > Media Center 2005 Infrared Remote Control and receiver (OEM) will work on > Vista out of the box. > Try another USB port ( but do think its at) or pull the batteries out 1/2 > hour( at sould clear the remote) or try new batteries. > > -- > Richard A Miller MCE mvp > http://www.microsoft.com/mvp > > > > > "Amar" wrote: > > > I have the WinXP Media Center Infrared Remote Control (OEM) that I have used > > successfully with Windows MCE 2005. I am now running Vista Premium Home > > Edition and would like to use the same remote with it. When I plug in the USB > > IR Receiver, Vista recognizes it and it shows up in my device properties. > > However, the red light on the receiver never turns on as it did on my MCE > > 2005 machine. With this, the remote does not work. > > > > Any ideas on how to get the WinXP Media Center Infrared Remote Control to > > work with Vista? |
| | #6 (permalink) |
| | Re: Remote Control for Vista Premium Home Edition I believe I am having a similar problem. I just got a brand new Media Center remote from Microsoft. The USB is recognized correctly (eHome Infrared Receiver). The RC light's up when I click any button (so it is working) and the receiver also blinks a red light. I can't make this thing work on my Vista Ultimate (32bits), none of the buttons work in Media Center. - Batteries are new. - Already Uninstalled eHome Infrared Receiver from device manager and reinstalled. - Already booted the pc. - Also tried to disable FFDSHOW as some people had related problems with it. I believe this remote should work, as it was announced as Vista compatible and I don't see many people complaining. I don't have a TV Tuner, as I intend to use the remote to simply play WMP files and control volume. Anyone have any idea on how to make the remote work in my Vista? |
| | #7 (permalink) |
| | Re: Remote Control for Vista Ultimate I have exactly the same problem with the MSFT WinXP Media Center remote. Notihing works on Vista. Anyone found a workaround on this in the last couple of months? Thanks!! "Shadow133" wrote: Quote: > I believe I am having a similar problem. I just got a brand new Media Center > remote from Microsoft. The USB is recognized correctly (eHome Infrared > Receiver). The RC light's up when I click any button (so it is working) and > the receiver also blinks a red light. I can't make this thing work on my > Vista Ultimate (32bits), none of the buttons work in Media Center. > > - Batteries are new. > - Already Uninstalled eHome Infrared Receiver from device manager and > reinstalled. > - Already booted the pc. > - Also tried to disable FFDSHOW as some people had related problems with it. > > I believe this remote should work, as it was announced as Vista compatible > and I don't see many people complaining. I don't have a TV Tuner, as I intend > to use the remote to simply play WMP files and control volume. Anyone have > any idea on how to make the remote work in my Vista? > |
| | #8 (permalink) |
| | Re: Remote Control for Vista Ultimate What problem do you have? The remote doesn't work at all or just certain commands don't work? I have a HP laptop with Vista Ultimate 64 and my original XP MCE Remote and Keyboard work flawlessly with Vista. Perhaps a hardware issue, what are the hardware specs? Was this a new Vista system or an upgrade? -- James Orlando (Goofy says "Hey!"), FL "ciccio" <ciccio@xxxxxx> wrote in message news:01D73DD7-F4F8-4859-A15A-665D8DBA4D25@xxxxxx Quote: > I have exactly the same problem with the MSFT WinXP Media Center remote. > Notihing works on Vista. Anyone found a workaround on this in the last > couple > of months? > > Thanks!! > > "Shadow133" wrote: > Quote: >> I believe I am having a similar problem. I just got a brand new Media >> Center >> remote from Microsoft. The USB is recognized correctly (eHome Infrared >> Receiver). The RC light's up when I click any button (so it is working) >> and >> the receiver also blinks a red light. I can't make this thing work on my >> Vista Ultimate (32bits), none of the buttons work in Media Center. >> >> - Batteries are new. >> - Already Uninstalled eHome Infrared Receiver from device manager and >> reinstalled. >> - Already booted the pc. >> - Also tried to disable FFDSHOW as some people had related problems with >> it. >> >> I believe this remote should work, as it was announced as Vista >> compatible >> and I don't see many people complaining. I don't have a TV Tuner, as I >> intend >> to use the remote to simply play WMP files and control volume. Anyone >> have >> any idea on how to make the remote work in my Vista? >> |
| | #9 (permalink) |
| | Re: Remote Control for Vista Ultimate "ciccio" <ciccio@xxxxxx> wrote in message news:01D73DD7-F4F8-4859-A15A-665D8DBA4D25@xxxxxx Quote: Quote: >> I believe I am having a similar problem. I just got a brand new Media >> Center >> remote from Microsoft. The USB is recognized correctly (eHome Infrared >> Receiver). The RC light's up when I click any button (so it is working) >> and >> the receiver also blinks a red light. I can't make this thing work on my >> Vista Ultimate (32bits), none of the buttons work in Media Center. >> >> - Batteries are new. >> - Already Uninstalled eHome Infrared Receiver from device manager and >> reinstalled. >> - Already booted the pc. >> - Also tried to disable FFDSHOW as some people had related problems with >> it. >> >> I believe this remote should work, as it was announced as Vista >> compatible >> and I don't see many people complaining. I don't have a TV Tuner, as I >> intend >> to use the remote to simply play WMP files and control volume. Anyone >> have >> any idea on how to make the remote work in my Vista? > >I have exactly the same problem with the MSFT WinXP Media Center remote. > Notihing works on Vista. Anyone found a workaround on this in the last > couple > of months? Update. It was shortly after Vista was released, IIRC. They way I got it working was the same method described here: http://blogs.msdn.com/astebner/archi...31/458928.aspx I think that will work, but of it does not, try reading this too: http://blogs.msdn.com/astebner/archi...24/484423.aspx ss. |
| | #10 (permalink) |
| | Re: Remote Control for Vista Ultimate similar issue here... unplug it and plug back in after each and every boot and it works fine... driver just will NOT stay installed ... so i guess its back to LINUX sorry to be abbrupt with my oppinion about microcraps issues that they never will resolve.... "Synapse Syndrome" wrote: Quote: > "ciccio" <ciccio@xxxxxx> wrote in message > news:01D73DD7-F4F8-4859-A15A-665D8DBA4D25@xxxxxx Quote: Quote: > >> I believe I am having a similar problem. I just got a brand new Media > >> Center > >> remote from Microsoft. The USB is recognized correctly (eHome Infrared > >> Receiver). The RC light's up when I click any button (so it is working) > >> and > >> the receiver also blinks a red light. I can't make this thing work on my > >> Vista Ultimate (32bits), none of the buttons work in Media Center. > >> > >> - Batteries are new. > >> - Already Uninstalled eHome Infrared Receiver from device manager and > >> reinstalled. > >> - Already booted the pc. > >> - Also tried to disable FFDSHOW as some people had related problems with > >> it. > >> > >> I believe this remote should work, as it was announced as Vista > >> compatible > >> and I don't see many people complaining. I don't have a TV Tuner, as I > >> intend > >> to use the remote to simply play WMP files and control volume. Anyone > >> have > >> any idea on how to make the remote work in my Vista? > > > >I have exactly the same problem with the MSFT WinXP Media Center remote. > > Notihing works on Vista. Anyone found a workaround on this in the last > > couple > > of months? > My MCE Remote stopped working when an eHome update came through on Windows > Update. It was shortly after Vista was released, IIRC. They way I got it > working was the same method described here: > > http://blogs.msdn.com/astebner/archi...31/458928.aspx > > I think that will work, but of it does not, try reading this too: > > http://blogs.msdn.com/astebner/archi...24/484423.aspx > > ss. > > > |
| Windows Vista Home Premium and XP Home Edition | Vista installation & setup | |||
| Sync Vista Home Premium with XP Home Edition | General Discussion | |||
| XP Home Edition to Vista 32-bit Home Premium | Vista networking & sharing | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Remote Desktop - XP Home taking control of Vista Home Premium | Vista General | |||
