Vista - Xbox 360 and Vista extender problems.
Old 06-09-2006   #1 (permalink)
Kris
I have the public beta 2 of vista and a Xbox 360. When I try to connect..I
get the launch screen and it briefly goes to the main menu, then shuts and
says "closing desktop".... then the 360 leaves this error:
"The Xbox has disconnected because an application has launched UI
unexpectedly. Would you like to reconnect?"
It then continues to do this over and over.......
Any suggestions???
Cheers
kris
Old 06-09-2006   #2 (permalink)
Andre Da Costa [Extended64]
Re: Xbox 360 and Vista extender problems.
Are there any open applications when you try to connect the XBOX to Vista
such as Media Player or Media Center for example? Try closing out all
applications and connect again. If the problem persist, I suggest reporting
the issue.
For Feedback:
http://go.microsoft.com/fwlink/?linkid=55160
Feedback reporting tool:
http://go.microsoft.com/fwlink/?linkid=43655
You might also want to post this in the Media Center newsgroup where others
might be experiencing the same and be able to give you better answer or
possible work around:
http://windowshelp.microsoft.com/com...7-c6829af79b0d
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Kris" <Kris@discussions.microsoft.com> wrote in message
news:2EE84D07-F5CF-411D-8DFF-E922ADFC7C77@microsoft.com...
> Any suggestions???
> Cheers
> kris
XBOX 360/Media Extender -- Can't connect to xbox live after configuring extender... Vista General
Vista MCE + Xbox 360 extender SLOW Vista General
Re: XBOX Extender Program does not find XBOX Vista General
Xbox 360 and Extender problems in Vista Vista General
