| | Xbox 360 and Extender problems in Vista I have the public beta 2 of vista and a Xbox 360. When I try to connect..I get the launch screen and it briefly goes to the main menu, then shuts and says "closing desktop".... then the 360 leaves this error: "The Xbox has disconnected because an application has launched UI unexpectedly. Would you like to reconnect?" It then continues to do this over and over....... Any suggestions??? Cheers kris |
| | Re: Xbox 360 and Extender problems in Vista Are there any open applications when you try to connect the XBOX to Vista such as Media Player or Media Center for example? Try closing out all applications and connect again. If the problem persist, I suggest reporting the issue. For Feedback: http://go.microsoft.com/fwlink/?linkid=55160 Feedback reporting tool: http://go.microsoft.com/fwlink/?linkid=43655 You might also want to post this in the Media Center newsgroup where others might be experiencing the same and be able to give you better answer or possible work around: http://windowshelp.microsoft.com/com...7-c6829af79b0d -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "Kris" <Kris@discussions.microsoft.com> wrote in message news:B4B3998B-B952-4FE0-9C37-76C9E33BF043@microsoft.com... >I have the public beta 2 of vista and a Xbox 360. When I try to connect..I > get the launch screen and it briefly goes to the main menu, then shuts and > says "closing desktop".... then the 360 leaves this error: > > "The Xbox has disconnected because an application has launched UI > unexpectedly. Would you like to reconnect?" > > It then continues to do this over and over....... > > Any suggestions??? > > Cheers > kris > |
| | Re: Xbox 360 and Extender problems in Vista Also check the Application, System, and Security Event Viewer logs (right click My Computer --> Manage) for any errors corresponding to the time that you tried to connect and then post them here. -- -- Andre Windows Connected | http://www.windowsconnected.com Extended64 | http://www.extended64.com Blog | http://www.extended64.com/blogs/andre http://spaces.msn.com/members/adacosta "Kris" <Kris@discussions.microsoft.com> wrote in message news:B4B3998B-B952-4FE0-9C37-76C9E33BF043@microsoft.com... >I have the public beta 2 of vista and a Xbox 360. When I try to connect..I > get the launch screen and it briefly goes to the main menu, then shuts and > says "closing desktop".... then the 360 leaves this error: > > "The Xbox has disconnected because an application has launched UI > unexpectedly. Would you like to reconnect?" > > It then continues to do this over and over....... > > Any suggestions??? > > Cheers > kris > |
| XBOX 360/Media Extender -- Can't connect to xbox live after configuring extender... | Vista General | |||
| Vista MCE + Xbox 360 extender SLOW | Vista General | |||
| Re: XBOX Extender Program does not find XBOX | Vista General | |||
| Xbox 360 and Vista extender problems. | Vista General | |||
