| | Satta HHD Problem After Install Ive just installed Vista Premium OEM on my pc and once it had finished installing i checked in my computer only to find 2 off my sata hdd's are not showing. Ive gone into the disk manager and they are listed but are showing as offline. When i right click on them the only option i have is to " convert to basic disk" I presume this will wipe the disks which i really dont want to do as they are full off stuff i want to keep. Ive used the help and tried to bring them online via the command promt using the "Diskpart" command but get the error "Diskpart encountered an error while onlining the objects in the pack associated with the selected disk" Is there anyway i can save the data on the disks..? Can anyone explain why this has happened...? Not a very great start to Vista for me. The disks are dynamic by the way.. Many Thanks in advance for anyone who takes the time to read this and reply.. |
| | RE: Satta HHD Problem After Install I've had a similar problem and just found a solution thx to someone @ msfn.org, although I must admit I've already converted my disks back to basic: "After a frustrating weekend trying to get my two dynamic drives working with Vista I finally figured it out: 1. Vista only supports Dynamic drives in Business and Ultimate - not Home Premium. I upgraded from XP Pro to Home Premium. Try to find out where Microsoft tells you that Premium doesn't support dynamic drives - I couldn't. Microsoft wanted me to upgrade to Ultimate for an additional $ 169 . . . I didn't want to. 2. It turns out that unless you are really using the features of dynamic drives you can easily switch them back to basic (so Vista can see them) without data loss. The instructions are right here (forget the ad): http://thelazyadmin.com/index.php?/a...sic-Disks.html The trick is to find diskprobe.exe. I took it out of the support cabinet on my old Windows 2000 disk. If you are running Vista you can not download it from Microsoft. Best bet is to pull it off an old windows disk. It worked perfectly and was really really simple. Be sure to 'run as administrator' when you run the software. I hope this saves everyone lots of time (and money)." "RaM" wrote: > Ive just installed Vista Premium OEM on my pc and once it had finished > installing i checked in my computer only to find 2 off my sata hdd's are not > showing. > Ive gone into the disk manager and they are listed but are showing as > offline. > When i right click on them the only option i have is to " convert to basic > disk" > I presume this will wipe the disks which i really dont want to do as they > are full off stuff i want to keep. > Ive used the help and tried to bring them online via the command promt using > the "Diskpart" command but get the error "Diskpart encountered an error > while onlining the objects in the pack associated with the selected disk" > Is there anyway i can save the data on the disks..? > Can anyone explain why this has happened...? > > Not a very great start to Vista for me. > > The disks are dynamic by the way.. > > Many Thanks in advance for anyone who takes the time to read this and > reply.. > |
| sp1 install problem | Windows Updates | |||
| WLM Install problem | Vista mail | |||
| RC1 install problem: Disk does not meet the criteria to install vi | Vista installation & setup | |||
| Install problem | Vista hardware & devices | |||
| Yet another install problem | Vista installation & setup | |||
