Vista - System Restore in Vista and Raid 1 no work?
Old 01-28-2007   #1 (permalink)
jimmy fallon
I seem to be able to create system restore points manually in vista, but the
automatic ones never get created. Are there any problems with system restore
and a Raid 1 system in general that anyone knows about? The main reason I ask
is, I had previously tried to install a 3rd internal hard disk for a backup
drive. As Murphy would have it, my system ceased to boot after that. Using
the Vista Cd I booted to the repair screen, and it told me there were no
restore points available. I was able to unplug one of the other Raid drives
and boot to the desktop, but then when I copied my critical files to a flash
drive, i didn't discover till I tried to restore them that there were only
parts of the files that were correctly copied. Lost a LOT of data.
I don't want to try it, but now i'm leary that the manually created system
restore points will even work.
thanks...
jf
Old 01-28-2007   #2 (permalink)
JackM
RE: System Restore in Vista and Raid 1 no work?
Restore points do work in Vista and are a contributing part of its backup
system.
Your problem can be caused if you are running dual boot with Win XP as
everytime you boot XP it wipes out the restore points in Vista. Do not
believe that RAID 0 has anything to do with it.
Several earlier threads available on this subject.
> thanks...
> jf
Old 01-28-2007   #3 (permalink)
jimmy fallon
Not dual booting, just booting to a Raid 1 system.
That has a slave drive as a backup.
jf
> system.
> > thanks...
> > jf
System Restore doesn't work Vista General
system restore in vista dont work System Security
System restore and other system apps do not work Vista General
System Restore Doesn't work Vista Home Premium Vista security
system restore wont work/cant boot into safe mode (vista home) Vista General
