| | A EULA issue regarding the Daily Tech installation workaround The Vista EULA states: "8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement only gives you some rights to use the software. Microsoft reserves all other rights. Unless applicable law gives you more rights despite this limitation, you may use the software only as expressly permitted in this agreement. In doing so, you must comply with any technical limitations in the software that only allow you to use it in certain ways. For more information, see http://www.microsoft.com/licensing/userights. You may not · work around any technical limitations in the software; (snip) The procedure in the DT article may be covered by this provision. At the very least, I would check with MS to see if does before recommending it to others. Now, guys, fire away. |
| | Re: A EULA issue regarding the Daily Tech installation workaround >You may not work around any technical limitations in the software I've never liked that statement.... I'm not even sure what that could possibly cover. -Michael "Colin Barnhorst" <colinbarharst@msn.com> wrote in message news:4EA92999-9E8B-4043-9226-003DF7C9EF8E@microsoft.com... > The Vista EULA states: > > "8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement only gives you some > rights to use the software. Microsoft reserves all other rights. Unless applicable law gives > you > more rights despite this limitation, you may use the software only as expressly permitted in > this > agreement. In doing so, you must comply with any technical limitations in the software that > only > allow you to use it in certain ways. For more information, see > http://www.microsoft.com/licensing/userights. You may not > · work around any technical limitations in the software; > (snip) > > The procedure in the DT article may be covered by this provision. At the very least, I would > check with MS to see if does before recommending it to others. > > Now, guys, fire away. |
| | Re: A EULA issue regarding the Daily Tech installation workaround "Colin Barnhorst" wrote > The Vista EULA states: > > "8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement > only gives you some > rights to use the software. Microsoft reserves all other rights. Unless > applicable law gives you > more rights despite this limitation, you may use the software only as > expressly permitted in this > agreement. In doing so, you must comply with any technical limitations in > the software that only > allow you to use it in certain ways. For more information, see > http://www.microsoft.com/licensing/userights. You may not > · work around any technical limitations in the software; > (snip) > > The procedure in the DT article may be covered by this provision. At the > very least, I would check with MS to see if does before recommending it to > others. Say it is in fact a violation of the EULA, there is no way to know that was done, is there? So in effect there is no practical way to enforce it. Knowing something is a violation of the EULA has an impact on some, but others don't care. Moving an OEM copy of the OS to a new computer, then lying when calling in for activation, is no problem for some folks. With no teeth to the enforcement it opens things wide for dual boot with the qualifying OS, selling that OS, installing it on another system, etc. I can't believe they left open this door. -- Rock [MVP - User/Shell] |
| | Re: A EULA issue regarding the Daily Tech installation workaround The EULA of discussion has one implied purpose; legally protecting Microsoft and Vista's OS from not-authorized OS modifications. Regardless if the source is licensed builders, OEMs, third party software vendors, and specifically any and all persons attempting to weaken Kernel Patch Protection, hash, serial numbers, matching points, and obviously includes whackers and hackers. Win XP has a very similar EULA. The legal difference regarding Vista'a EULA, the Vista EULA includes a Giant Bear Trap that's loaded and ready for springing into action, instantly. Microsoft's incredible Jim Allchinn has several online articles extensively sharing the security reasons for the importance for legally protecting Kernel Patch Protection, as well as Vista's entire OS. Who benefits the most from Vista's EULA? Does our entire world benefit the most? Why you ask; for sustaining the most state-of-the-art ultra secure OS as Windows Vista. Microsoft has many legal professionals ready and fully prepared for pursuing litigation toward the first character that attempts modification of the Kernel Patch Protection. The word "attempts" is used because Microsoft's silent online Security instantly identifies any attempts for illegally modifying Vista's OS. Again, who receives the most factual benefit from the EULA while using Windows Vista? -- Windows Vista Become Part of The Legacy! "Rock" wrote: > "Colin Barnhorst" wrote > > > The Vista EULA states: > > > > "8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement > > only gives you some > > rights to use the software. Microsoft reserves all other rights. Unless > > applicable law gives you > > more rights despite this limitation, you may use the software only as > > expressly permitted in this > > agreement. In doing so, you must comply with any technical limitations in > > the software that only > > allow you to use it in certain ways. For more information, see > > http://www.microsoft.com/licensing/userights. You may not > > · work around any technical limitations in the software; > > (snip) > > > > The procedure in the DT article may be covered by this provision. At the > > very least, I would check with MS to see if does before recommending it to > > others. > > Say it is in fact a violation of the EULA, there is no way to know that was > done, is there? So in effect there is no practical way to enforce it. > Knowing something is a violation of the EULA has an impact on some, but > others don't care. Moving an OEM copy of the OS to a new computer, then > lying when calling in for activation, is no problem for some folks. With no > teeth to the enforcement it opens things wide for dual boot with the > qualifying OS, selling that OS, installing it on another system, etc. I > can't believe they left open this door. > > -- > Rock [MVP - User/Shell] > > |
| | Re: A EULA issue regarding the Daily Tech installation workaround Don't you think that, if you are going to drop his name (as you do with all the Important People that you pretend to know), that you should at least spell it correctly, "Frankie"**? http://www.microsoft.com/presspass/e...m/default.mspx ** http://windowsvistablog.com/blogs/wi...fast-lane.aspx -- Maxwell Bluemeanie Exposing "Vista Ready" bit by bit "Jonathan Schwartz 2" <JonathanSchwartz2@discussions.microsoft.com> wrote in message news:FDDB396E-40FD-44A1-936B-43F2CE38BB63@microsoft.com... > > Microsoft's incredible Jim Allchinn has several online articles > extensively > sharing the security reasons for the importance for legally protecting > Kernel > Patch Protection, as well as Vista's entire OS. |
| | #6 (permalink) |
| | Re: A EULA issue regarding the Daily Tech installation workaround On Thu, 01 Feb 2007 00:11:16 -0500, MICHAEL wrote: > >>You may not work around any technical limitations in the software > > I've never liked that statement.... I'm not even sure what that could > possibly cover. And I don't see what "work around" was used - if the installer permits the described actions, then it's not a work around. -- Leythos spam999free@rrohio.com (remove 999 for proper email address) |
| | #7 (permalink) |
| | Re: A EULA issue regarding the Daily Tech installation workaround On Wed, 31 Jan 2007 22:05:07 -0700, "Colin Barnhorst" <colinbarharst@msn.com> wrote: >The Vista EULA states: > >"8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement >only gives you some >rights to use the software. Microsoft reserves all other rights. Unless >applicable law gives you >more rights despite this limitation, you may use the software only as >expressly permitted in this >agreement. In doing so, you must comply with any technical limitations in >the software that only >allow you to use it in certain ways. For more information, see >http://www.microsoft.com/licensing/userights. You may not >· work around any technical limitations in the software; >(snip) > >The procedure in the DT article may be covered by this provision. At the >very least, I would check with MS to see if does before recommending it to >others. > >Now, guys, fire away. Don't see any problem at all with this. The functionality to do the clean install work around is built into the Setup.exe program which comes with the Official MS version of Vista. This means it was released by MS and that they know that this functionality exists. You are not bypassing any technical limitations if you simply know about a non-published function that is built into the program. |
| | #8 (permalink) |
| | Re: A EULA issue regarding the Daily Tech installation workaround In article <4EA92999-9E8B-4043-9226-003DF7C9EF8E@microsoft.com>, Colin Barnhorst wrote: > You may not work around any technical limitations in the software; I suspect Microsoft's Lawyers overlooked the difference between "limitation" and "limit" ? If there's a bug and I install a Microsoft fix I am working around the "limitation in ths software as I bought it which they should want me to do. If there's something there to stop be doing something they don't want me to do and I find a way round that I am working around the "limit in the software" which they do not want me to do |
| | #9 (permalink) |
| | Re: A EULA issue regarding the Daily Tech installation workaround It is a workaround because elsewhere in the EULA the user is prohibited from continuing to use the operating system that qualified for upgrade/replacement. "Leythos" <Void@nowhere.com> wrote in message news:1170327295_4737@sp6iad.superfeed.net... > On Thu, 01 Feb 2007 00:11:16 -0500, MICHAEL wrote: >> >>>You may not work around any technical limitations in the software >> >> I've never liked that statement.... I'm not even sure what that could >> possibly cover. > > And I don't see what "work around" was used - if the installer permits > the described actions, then it's not a work around. > > -- > Leythos > spam999free@rrohio.com (remove 999 for proper email address) |
| | #10 (permalink) |
| | Re: A EULA issue regarding the Daily Tech installation workaround For example, since Vista home editions are permitted in the EULA to have no more than 5 inbound connections and Business is permitted 10, a registry or other modification to allow 10 in Home is deemed exceeding the scope of the Home license and puts you out of compliance. There are lots of other edition-specific limitations that are enforced in the technology by registry keys and such. Just because you know how to exceed the limitations specified in the EULA does not keep you from being out of compliance when you do it. In this case, if an upgrade edition license prohibits continued use of the software after its license has been subsumed by the upgrade license, then the mere fact that you can make it work anyway (working around the technical limitation) does not make it OK to do so. I want to reemphacize that because this is a licencing issue, whatever you decide to do on your own machine, don't give out advice to other users to do it unless you can get confirmation from a Microsoft local office that it does not create an out of compliance situation in your region. Remember, like OEM restrictions, this can vary according to your region. "MICHAEL" <u158627_emr@dslr.net> wrote in message news:%23raOs9bRHHA.4692@TK2MSFTNGP02.phx.gbl... > >You may not work around any technical limitations in the software > > I've never liked that statement.... I'm not even sure what that could > possibly cover. > > -Michael > > "Colin Barnhorst" <colinbarharst@msn.com> wrote in message > news:4EA92999-9E8B-4043-9226-003DF7C9EF8E@microsoft.com... >> The Vista EULA states: >> >> "8. SCOPE OF LICENSE. The software is licensed, not sold. This agreement >> only gives you some >> rights to use the software. Microsoft reserves all other rights. Unless >> applicable law gives you >> more rights despite this limitation, you may use the software only as >> expressly permitted in this >> agreement. In doing so, you must comply with any technical limitations in >> the software that only >> allow you to use it in certain ways. For more information, see >> http://www.microsoft.com/licensing/userights. You may not >> · work around any technical limitations in the software; >> (snip) >> >> The procedure in the DT article may be covered by this provision. At the >> very least, I would check with MS to see if does before recommending it >> to others. >> >> Now, guys, fire away. > |
| those still having the driver stopped working issue..possible workaround!! | Graphic cards | |||
| Can I force installation of a daily planner? | Vista General | |||
| Dell Installation Workaround? | Vista installation & setup | |||
| 2 'New' Installation MSKBs/EULA Change/Anytime Upgrade FAQ | Vista General | |||
| 2 'New' Installation MSKBs/EULA Change/Anytime Upgrade FAQ | Vista installation & setup | |||
