| Guest | NT Kernel & System (Resource Monitor) Not that this is too big of a deal but I noticed that for about five to ten minutes after Vist starts The NT Kernal & System listing in the Resource Manager maxes out my CPU, then every once in a while after that. I'm not a techy person so can anyone tell me why this is happening? |
| Guest | Re: NT Kernel & System (Resource Monitor) Behind Vistas shiny new Interface there are running hundreds of hidden tasks and services. Tablet-PC input service is running, expecting any minute you could use a pen instead of a mouse, regardless that your PC most likely is no Tablet, but a normal Laptop or PC.. Time-Synchronizers,Windows Defender scanning the content of the Data in RAM and of course the Desktop Search and it is indexing all your folders silently, the same appplies to the Defrag Utility that now starts regulary hidden behind the scenes and is arranging data on your disk. Performance-indicator for all OS componebts are measuring data, the NT system itself is logging what the hell and you have assitants to report errors , solve Problems and the like. Also the new Superfetch loads you allday used programs into the RAM of your machine, regardless if you intend to use them.. Solution : buy more RAM ( with more than 2 GB it is ok to have all running )and a even faster Cpu than the recommended 1 GhZ and/ or get used to NT-services and how to configure the Defaults to your personal needs ( I could deactivate over a dozen for me ), learn how to tweak Vistas Resource hunger down by disabling some of those stuff. At MS Website there is a tool exctrlst.exe which lets you disable the performance-ghosts running all time. With Tweakvi ( freeware) you can do great "magic" to performance the rest is handwork.. like I said - NT-Serives, but that needs a bit knowledge in what is safe to disable and what not. to see things speed up instantly - do right click "Computer", go "advanced Options" and tell Vista to "best perfomrance" . this will disable the new UI and trim the Optics to what shall resemble Windows 95 look, that safes the first 50 or so MB in RAM .. Windows - Search you can set in folder options to not use the index, but let search file-names alone, that speeds up also and makes the running index service obsolete. Every "disablement" of course has its pros and cons.. You just bought a new Windows only to reduce its power and let it look like a ten year old OS.. anyhow that is the only way for slower Pcs now. regards "shay" <shay@discussions.microsoft.com> schrieb im Newsbeitrag news:71D01F19-3A75-4E46-A5CB-E71329262153@microsoft.com... > Not that this is too big of a deal but I noticed that for about five to > ten > minutes after Vist starts The NT Kernal & System listing in the Resource > Manager maxes out my CPU, then every once in a while after that. I'm not a > techy person so can anyone tell me why this is happening? |
| Newbie | Re: NT Kernel & System (Resource Monitor) |
| Can't open Resource monitor | General Discussion | |||
| Resource Monitor | Tutorials | |||
| Resource Monitor - CPU graph | Vista performance & maintenance | |||
| Resource Monitor - system becomes unresponsive /netowkr | Vista performance & maintenance | |||
| resource monitor | Vista General | |||
