| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | SQL 2005 and Vista problem Hi, When using Vista it cannot connect to a SQL 2005. We first discovered this in our ptogram, and then I tested it in the ODBC control panel. It says that it cannot find the SQL server..... When connecting to a SQL 2000 it works fine. This is only a problem in Vista. Works great in 98/2000/XP Thanks, David |
| Guest | Re: SQL 2005 and Vista problem Are you trying to connect from local machine to local SQL Server? I just installed both and have no problems. If you are trying to connect from another workstation this I have not tried. It may have to do with computer browser service which I notice is not turned on. LLoyd Sheen "David DB" <er_fortsatt@hotmail.com> wrote in message news:OnwAKMyRHHA.2228@TK2MSFTNGP03.phx.gbl... > Hi, > > When using Vista it cannot connect to a SQL 2005. > > We first discovered this in our ptogram, and then I tested it in the ODBC > control panel. It says that it cannot find the SQL server..... > > When connecting to a SQL 2000 it works fine. > > This is only a problem in Vista. Works great in 98/2000/XP > > Thanks, > David > |
| Guest | Re: SQL 2005 and Vista problem Hi Lloyd! On the same machine I also have Win XP, and there it works. The SQL 2005/SQL 2000 is on a Win 2003 server. David "Lloyd Sheen" <a@b.c> wrote in message news:CB042C96-DAB6-4617-B108-A4EEF319B7A2@microsoft.com... > Are you trying to connect from local machine to local SQL Server? > > I just installed both and have no problems. If you are trying to connect > from another workstation this I have not tried. It may have to do with > computer browser service which I notice is not turned on. > > LLoyd Sheen > > "David DB" <er_fortsatt@hotmail.com> wrote in message > news:OnwAKMyRHHA.2228@TK2MSFTNGP03.phx.gbl... >> Hi, >> >> When using Vista it cannot connect to a SQL 2005. >> >> We first discovered this in our ptogram, and then I tested it in the ODBC >> control panel. It says that it cannot find the SQL server..... >> >> When connecting to a SQL 2000 it works fine. >> >> This is only a problem in Vista. Works great in 98/2000/XP >> >> Thanks, >> David >> > |
| Guest | Re: SQL 2005 and Vista problem What authentication mode does the sql server use? If it's Windows make sure your Vista user is added. -- Kerry Brown Microsoft MVP - Shell/User http://www.vistahelp.ca "David DB" <er_fortsatt@hotmail.com> wrote in message news:OnwAKMyRHHA.2228@TK2MSFTNGP03.phx.gbl... > Hi, > > When using Vista it cannot connect to a SQL 2005. > > We first discovered this in our ptogram, and then I tested it in the ODBC > control panel. It says that it cannot find the SQL server..... > > When connecting to a SQL 2000 it works fine. > > This is only a problem in Vista. Works great in 98/2000/XP > > Thanks, > David > |
| Guest | Re: SQL 2005 and Vista problem Search for Vista in "Readme for Microsoft SQL Server 2005 Service Pack 2": http://download.microsoft.com/downlo..._windows_vista "David DB" <er_fortsatt@hotmail.com> wrote in message news:OnwAKMyRHHA.2228@TK2MSFTNGP03.phx.gbl... > Hi, > > When using Vista it cannot connect to a SQL 2005. > > We first discovered this in our ptogram, and then I tested it in the ODBC > control panel. It says that it cannot find the SQL server..... > > When connecting to a SQL 2000 it works fine. > > This is only a problem in Vista. Works great in 98/2000/XP > > Thanks, > David > |
| Display Modes | |
| Upgrade Problem--XP Media Center 2005 to Vista Home Premium | Jeff | Vista General | 3 | 08-20-2007 06:46 PM |
| VS 2005 intellisense problem | raj | Vista General | 0 | 07-09-2007 08:28 PM |
| Installing Visual Studio 2005 Std Ed, SQL Server 2005 Expr./Compac | Stéphane | Vista installation & setup | 4 | 04-28-2007 11:20 AM |
| IIS 7 & Sql Server 2005 Setup problem | Mr. Murad Jamal | Vista General | 4 | 11-22-2006 02:13 AM |
| IIS 7 & Sql Server 2005 Setup problem | Mr. Murad Jamal | Vista installation & setup | 2 | 11-21-2006 09:41 AM |
