Vista - 64 Bit System Builder key on 32 Bit?
Old 02-02-2007   #1 (permalink)
Hal9000
Hello!
I bought a Vista Ultimate 64 Bit System Builder, and an Ultimate 32 Bit
System Builder DVD. So I have two product keys.
BUT: can I use both keys to install the 32 bit version, and keep the 64 bit
DVD for future use? It turned out I can't use 64 bit for now due to Cisco
VPN...
hal
Old 02-03-2007   #2 (permalink)
Max
Re: 64 Bit System Builder key on 32 Bit?
Chances are, you can, yes.
From what I understand, there is no difference between a product key for a
32 bit vs. a 64 bit version of the same flavor of Vista.
Maxwell Bluemeanie
"Hal9000" <devnull@nowhere.com> wrote in message
news:2B796996-7B1B-4C2C-AFE2-AD3A1B2164F0@microsoft.com...
> Hello!
> bit
> VPN...
> hal
Old 02-03-2007   #3 (permalink)
John Whitworth
>> Hello!
>> bit
>> VPN...
>> hal
"Max" <max@home.com> wrote in message
news:%23QP$Tp3RHHA.2172@TK2MSFTNGP04.phx.gbl...
So the 64-bit key will have been 'spent' already on the 32-bit OS? Therefore
you may have activation issues when trying to reuse the product keys.
JW
Old 02-03-2007   #4 (permalink)
Max
That is a possibility. The 'Activate by phone...' option may have to be
used--with some potential explaining to a live service rep. Time will tell
if this is successful.
Maxwell Bluemeanie
"John Whitworth" <sexyjw@gEEEEEEEEEmail.com> wrote in message
news:O$KauL4RHHA.2228@TK2MSFTNGP03.phx.gbl...
>>> Hello!
>>> bit
>>> Cisco
>>> VPN...
>>> hal
>> a 32 bit vs. a 64 bit version of the same flavor of Vista.
> Therefore you may have activation issues when trying to reuse the product
> keys.
> JW
Old 02-03-2007   #5 (permalink)
LoneWolf
John & Max
And to add to that, they're both OEM's & will
be tied to the original machine they're installed on.
Or is it, 'you can move the OEM' once ?
> Maxwell Bluemeanie
> >>> Hello!
> >>> bit
> >>> Cisco
> >>> VPN...
> >>> hal
> > keys.
> > JW
Old 02-03-2007   #6 (permalink)
Max
Yup. Knew that. But in this situation (as described by the OP), it IS the
same, original, machine. Would just be going from 32 to 64 bit. I would
think (hope?) that there would be some phone authorization wiggle room to
allow for this--OEM or not--as long as it is still One Machine, One
License/PK.
Technically and legally (EULA-wise), no, I don't think so--OEM/System
Builder copies cannot be 'moved' or transfer the license to another machine.
Hence the Grey Area in this scenario.
Maxwell Bluemeanie
"LoneWolf" <LoneWolf@discussions.microsoft.com> wrote in message
news:B700ABB8-5321-419A-B54F-FF7525E91572@microsoft.com...
> John & Max
>> tell
>> Maxwell Bluemeanie
>> >>> Hello!
>> >>> Bit
>> >>> 64
>> >>> bit
>> >>> Cisco
>> >>> VPN...
>> >>> hal
>> >> for
>> > product
>> > keys.
>> > JW
How To Create System Builder Image? Software
System builder media replacement Vista General
RE: Replacing System Builder software? Vista General
OEM system builder pack? Vista General
OEM system builder pack Vista General
