ESPN Web TV does not work with Vista
  1. #1
    nofumble Guest
    I have tried to watch video clip from espn.com and CBS.com with Vista.
    I only got sounds, no video. I clicked on help and they tell I need
    Window Media player 10 (or 11 I forgot), or Real Player. Gruhmm, I
    should have the latest Media Player in the newly OS Vista bundle but
    how come it doesn't work. What version of Media Player in Vista. I
    can't find the "about" drop down in Vista Media Player.
    I am about to install Real Player. But I don't want it to be the
    default player.
  2. #2
    Jane C Guest
    Re: ESPN Web TV does not work with Vista
    Vista has Media Player 11 included.
    Jane, not plain 64 bit enabled :-)
    Batteries not included. Braincell on vacation ;-)
    "nofumble" <Davit62@gmail.com> wrote in message
    news:1170545975.399721.187210@a34g2000cwb.googlegroups.com...
    > default player.
  3. #3
    nofumble Guest
    Hmm. adding to the list:
    cnn.com
    msnbc.com
    Do anyone of you have same problem I have?
    let try this http://www.msnbc.msn.com/id/16957259/
    No problem in with google video through. What's the rpoblem here?
  4. #4
    MICHAEL Guest
    news:1170564696.270664.220570@h3g2000cwc.googlegroups.com...
    > cnn.com
    > msnbc.com
    Not sure. But, during beta testing several users reported that
    this worked; open an elevated command prompt (CMD run as administrator)
    copy and paste this-
    netsh int tcp set global autotuninglevel=disabled
    Then hit enter. You'll get an "OK" verifying it was set.
    If that doesn't work set it back with this-
    netsh int tcp set global autotuninglevel=normal
    Are using a router? Just curious.
    -Michael
  5. #5
    nofumble Guest
    Thanks for your suggestion but I don't understand what to do yet. Cut
    and paste from where to where? I am not an IT expert.
    Yes I am using a router. Same one as the other 3 PCs that still use XP
    and none of them has this problem whatsoever.
  6. #6
    MICHAEL Guest
    news:1170917611.152138.310810@a75g2000cwd.googlegroups.com...
    You can actually do this a few ways. We'll do it the old fashioned
    way.
    Type "CMD" in Start Menu's search box. You'll see one result.
    Right click it, select "Run as Administrator"
    Copy and paste this line below:
    Hit enter. You'll get an "Ok".
    Close the CMD window.
    See if that helps you.
    -Michael
  7. #7
    nofumble Guest
    Hi Michael, I tried that and get this message instead of OK
    Set global command failed on IPv4 The requested operation requires
    elevation.
  8. #8
    MICHAEL Guest
    news:1172431613.588150.77520@a75g2000cwd.googlegroups.com...
    > elevation.
    You have to right click CMD and select "Run as Administrator".
    -Michael
  9. #9
    nofumble Guest
    Thanks Michael. I didn't have to do anything. It works now. Either
    because of the new GMA graphic driver update from Intel, or the
    problem was fixed by MS or by the websites.
ESPN Web TV does not work with Vista problems?
speakers randomly wont work sometimes on laptop but external will sometime work khanster786 Sound & Audio 0 29 Jan 2009
Still searching for way to get Vista search to work: Why doesn't FilterFilesWithUnknownExtensions registry key work in Vista? Celegans Vista General 11 31 Aug 2007
Video capture of ESPN online PPV event gafhptva Vista music pictures video 0 16 Jul 2007
HP LaserJet 1010 don't work in Vista since Beta2 - Advanced 1384 Printing Support drivers for XP don't work Alexey Vista print fax & scan 2 18 Oct 2006
Will all the programs that work on xp work on vista? exciter Vista General 14 06 Oct 2006
