Vista - Vista - monitor doesnt power down
Old 02-04-2007   #1 (permalink)
Diamontina Cocktail
Any ideas why that would be, anyone? I have set it to do so after 10 mins
and it never does. Using my own power profile based on performance with that
one change.
Old 02-05-2007   #2 (permalink)
Rick Rogers
Re: Vista - monitor doesnt power down
Checked for a monitor.inf file from the manufacturer? Sometimes the basic
one in the OS doesn't do everything you want it to.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Diamontina Cocktail" <lrb@australia.com> wrote in message
news:u33y7HOSHHA.388@TK2MSFTNGP04.phx.gbl...
> that one change.
Old 02-05-2007   #3 (permalink)
Diamontina Cocktail
When I upgraded the OS, I originally had it go to the generic driver and had
to change back to the one I have for my monitor like I had before so yes I
have that. However, it is possible the driver I have isnt a happy little
Vista compatriot I suppose.
"Rick Rogers" <rick@mvps.org> wrote in message
news:%238IiApRSHHA.480@TK2MSFTNGP02.phx.gbl...
> Hi,
> Best of Luck,
>> that one change.
Old 02-05-2007   #4 (permalink)
mikeyhsd
does it shut down if you try balanced or power saver plans.
mikeyhsd@sport.rr.com
"Diamontina Cocktail" <lrb@australia.com> wrote in message news:u33y7HOSHHA.388@TK2MSFTNGP04.phx.gbl...
one change.
Old 02-05-2007   #5 (permalink)
Diamontina Cocktail
> "mikeyhsd" <mikeyhsd@sport.rr.com> wrote in message
> news:O6WlJHTSHHA.4028@TK2MSFTNGP04.phx.gbl...
Havent tried them. I assume that if it wont shut down under one plan, there
wont be any difference in any other because the monitor shutdown command is
the same in all cases. However, I may have come up with a solution now. I
have an ATI Radeon 9600 and I just found that www.ati.com have Vista
specific drivers not long released and am installing them at the moment.
Hoping that is the solution.
Old 02-18-2007   #6 (permalink)
Shane Nokes
My recommendation is never assume, always be willing to try what someone has
posted.
Software isn't perfect and sometimes little things like this will fix it.
news:OyTuxaWSHHA.1200@TK2MSFTNGP02.phx.gbl...
> there wont be any difference in any other because the monitor shutdown
> command is the same in all cases. However, I may have come up with a
> solution now. I have an ATI Radeon 9600 and I just found that www.ati.com
> have Vista specific drivers not long released and am installing them at
> the moment. Hoping that is the solution.
Vista restart power issue, monitor won't respond. Vista General
Vista Remote Desktop disables monitor power saving. Vista General
Vista and Monitor Power Saving Vista General
Vista and Monitor Power Saving Vista hardware & devices
Monitor doesnt turn off Vista hardware & devices
