Vista - Flash Player - MySpace Comment Section
Old 02-05-2007   #1 (permalink)
MDHATTAWAY
Ever since installing the Vista OS I am have serious issues with the Flash
Player not being recongnized as installed on this OS. Also when I am
connecting to the myspace website and I use this one because I am seeing it
on that page it will lot let certain parts of the webpage load up such as the
comments section when using HTML code to setup the website. Does anyone know
what I can do to try to rectify this problem?
Thanks,
Michael
Old 02-05-2007   #2 (permalink)
Cymbal Man Freq.
Re: Flash Player - MySpace Comment Section
"MDHATTAWAY" <MDHATTAWAY@discussions.microsoft.com> wrote in message
news:F5F6888E-69CA-4A83-884B-4CEDE0243F85@microsoft.com...
| Thanks,
| Michael
Quicktime 7.1 is goofed, a lot of problems. Check their forums. Probably no
satisfactory answers available.
Old 02-05-2007   #3 (permalink)
Synapse Syndrome
> it
> the
> know
When you use the Disk Cleanup thing and select to clean downloaded programs,
it deletes some Flash Player files, but still leaves IE thinking that Flash
is installed. This stops you from being able to install it from the Adobe
site. You need to find the standalone installer on the web. Here's one I
just found:
http://www.softwarepatch.com/internet/flash.html
ss.
myspace music player won't work on vista 64? Sound & Audio
flash player Vista General
FLASH PLAYER Vista General
windows media player-can not move cursor to next section Vista General
Flash Player Vista General
